After maintenance, truck needs to rev to 2k+ in order to accelerate.
Discussion in 'Technical Chat' started by pkal24, Jan 5, 2014.
  1. Jan 5, 2014 at 3:51 PM
    pkal24
    pkal24 [OP] New Member
    Paul
    2010 Tacoma
    none.
    Hey guys, my name is Paul and I have been following this forum for some time now. I am not one of those guys, although it may seem like it, who is posting for help and will not be around, I am just still learning and so instead of saying something dumb I just don't say anything at all. BLUF: I have a 2010 V6 double cab Tacoma with 42000 miles. I recently read the sticky on changing the plugs, oil, and lubricating the propellor shaft. The truck ran fine before I completed all of these maintenance tasks. Afterwards though, my truck now idles to 2,000 RPM before "kicking" into gear. Unfortunately I have troubleshot to the best of my ability and am seeking your guys' help please!
  2. Jan 5, 2014 at 4:00 PM
    Tacoma Mike
    Southern Maine
    Did u leave the vac line disconnected on drivers side intake. Will have a big sucking sound under the hood by the vertical intake support.
  3. Jan 5, 2014 at 5:13 PM
    pkal24
    Paul
    2010 Tacoma
    none.
    No, there is no sucking sound, and I went over all of the hoses and connections to make sure they terminated somewhere. I made certain all of the gaps on the plugs were correct also. I am stumped.
  4. Jan 5, 2014 at 5:16 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Sounds like a vacuum leak.
  5. Jan 5, 2014 at 5:23 PM
    Tacoma Mike
    Southern Maine
    Did u remove the air box section that attaches to the throttle body?
  6. Jan 5, 2014 at 5:28 PM
    Tacoma Mike
    Southern Maine
    He didn't mention a check engine light so I'm thinking he does.
    A disconnected sensor would kick it on right away.
    I think he's missing something.
  7. Jan 5, 2014 at 5:29 PM
    pkal24
    Paul
    2010 Tacoma
    none.
    No, I did remove the intake hose and air filter housing though. I am gonna go back out there and check one more time.
  8. Jan 5, 2014 at 5:35 PM
    Tacoma Mike
    Southern Maine
    Don't panic Paul.
    Go over in your mind what you did and how you did it.
