After market audio for Tacoma's Etc's
Discussion in 'Audio & Video' started by manethon, Jan 8, 2014.
  1. Jan 8, 2014 at 9:55 PM
    manethon
    manethon [OP] TTAS
    Steven
    Unknow
    Many
    For the general public mostly budget minded Etc what would you want to have access to ? The best value for dollars
    Good shallow mount 10/12s? What's max mounting depth?
    Small footprint mono amp to match ? 1200-1800wrms under 7x3x14?
    Mids, components, pa?
    Mid amp? 150x4? Bridgeable ? Or 75x4 f
    What I have found is that the Tacoma up front can easily take a 8 inch midbass/mid range driver.
    Id like comments or a list sothat I can see what people have and actually want:)
    Thanks gang!
  2. Jan 8, 2014 at 10:11 PM
    SoCalTacos
    SoCalTacos Turd runner
    socal
    2017 4Runner TRD Pro
    Led head/dtr lights.
    I have a Kenwood excelon dd..focal throughout the cab..JL stealthbox...arc audio amp...and dynamatted cab.
    She sounds good.
  3. Jan 9, 2014 at 11:52 AM
    ZMan2k2
    ZMan2k2 “Hold my beer and watch this!”
    Richard
    Under a tinfoil hat
    ‘25 SS Red Sport Prem.
    What I need is a 250Amp alternator that fits the stock location. My amp takes 150A running at 1ohm, and I could use the extra power so I don't drop to 12.2V while at an intersection or parked. Anything on that front?
    And the 8" midbass sounds interesting, can I use it with the crossover and tweeter that I have now, a JL C2-250?
  4. Jan 9, 2014 at 1:48 PM
    manethon
    manethon [OP] TTAS
    Steven
    Unknow
    Many
    We would have to look at the response of ur current cross over and make sure that it's in the same ball park for power and freq response
    Bolt on alts are in the works for gb.
    Im asking these questions as I'd love to go to certain people and put together a great package that's comparable and better than those main name brands( not as high end as the focal and hertz, hybrid audio etc) at a great price.
    First I gotta figure out what people actually want
  5. Jan 9, 2014 at 1:58 PM
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    Eclipse IN dash DVD/GPS, Memphis 300.4, Memphis 200.4, Memphis 1001.1, Focal Poly-Glass 3-ways, Polk 10". Will be doing the high end Pioneer in dash with blue tooth here in a bit as I am tired of having outdated maps and want to be able to sync my phone up via blue tooth.
  6. Jan 9, 2014 at 2:05 PM
    manethon
    manethon [OP] TTAS
    Steven
    Unknow
    Many
    can you guys post pics of amp and sub install?
    im not looking at head units
  7. Jan 9, 2014 at 2:17 PM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    AMP RACK
    Don't have any pics of the sub as I have yet to take any pics of the box nor have I carpeted the box or finish the rack I plan on doing for it.
  8. Jan 9, 2014 at 2:57 PM
    manethon
    manethon [OP] TTAS
    Steven
    Unknow
    Many
    Where is the sub mounted?
  9. Jan 9, 2014 at 2:58 PM
    manethon
    manethon [OP] TTAS
    Steven
    Unknow
    Many
    How much mounting depth is there behind the seat for a 12/10?
  10. Jan 9, 2014 at 3:22 PM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    right behind my seat, 10" polk SVC used .5" MDF wedge box design. about 3" off the back wall. Got about .75 cuft out of it empty....
  11. Jan 9, 2014 at 4:19 PM
    manethon
    manethon [OP] TTAS
    Steven
    Unknow
    Many
    oh right you have a reg cab...
    im trying to figure out what the max dim are behind the seat...
    im trying to see what the max is to figure out if i can get access to subs that will.
    for you in a reg, the options are actually endless:)
  12. Jan 9, 2014 at 4:25 PM
    ZMan2k2
    Richard
    Under a tinfoil hat
    Here's a pic of my setup. I have two Sundown Audio SA-2 10" subs and a SAX1500-D amp. Under the dash I have an Alpine KTP-445U running the front speakers. I would like to get the rear door speakers running, but the amp in the deck died, and I don't want to cut down the power of the Alpine to 45x4. Currently it's running 90x2.
  13. Jan 9, 2014 at 6:12 PM
    manethon
    manethon [OP] TTAS
    Steven
    Unknow
    Many
    thanks for the pics, thats exactly what i was looking for
  14. Jan 9, 2014 at 6:28 PM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Ooo I had a dual 10 " memphis subs with a full box in the back, two amps on top. Could not put the seat all the way back though...... ill see If I can find pics
  15. Jan 9, 2014 at 7:02 PM
    ZMan2k2
    Richard
    Under a tinfoil hat
    If you look close in my pic, you'll see that I brought the lock bar for the seat back forward about 1/2". It's still secure, because the bolts still have a good 1/2" of bite inthe crossbrace, but I can still put the seat all the way back and lock it in place. And without hitting the bracing bar in the seat itself.
  16. Jan 9, 2014 at 8:11 PM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    I built mine around my jack and tools. Amps went horizontal across the top, so enclosures stuck out more to accommodate airspace for the 10's
  17. Jan 9, 2014 at 10:11 PM
    manethon
    manethon [OP] TTAS
    Steven
    Unknow
    Many
    i actually when i had a system behind the seats move my back bench part forward on the mounting bolts and made a bracket to allow the rear hole of the bench to line up with the front hole in the truck, and extended the clips, i gained like 2-3 inches if i rem right.
    anyhow this is a good start, im asking these questions as im currently designing a package to present and see if Tw likes it. i cant use my truck as a mock due to my entire truck being stripped ----zman might find out on sunday haha
  18. Jan 10, 2014 at 8:29 AM
    jstarks
    jstarks Well-Known Member
    Louisiana
    09 Doublecab 4WD
    I need to get some better pictures but, my current set up is:
    Pioneer 80PRS, Alpine PDX v9, HAT Clarus 6.5's front and 5.25 rear, single 12 Kicker shallow that I had from a previous set up.
    What I will change/ or want to change:
    Swap the sub for a JL 13tw5 or completely redo the box/amp rack and put two JL 10tw3's
    Will move the tweeters to the sail panels. REALLY wish there were pre-fab aftermarket sail panels or A-pilars.
    May install a mid-range driver (3" or 4") in the stock tweeter location.
  19. Jan 10, 2014 at 11:10 AM
    ZMan2k2
    Richard
    Under a tinfoil hat
    Now you have my interest piqued. :D Can't wait for your help. I'll look at my grounds on Saturday, see if I can fix them up, but having some experienced eyes look at it will be appreciated.
  20. Jan 10, 2014 at 11:20 AM
    ONEBAR
    ONEBAR Well-Known Member
    Josh
    Englewood, CO
    08 White TRD OR
    Nice, That looks clean. I like your rack.. ;)
