after market backup camera install??
Discussion in 'Audio & Video' started by undermoneyed, Mar 25, 2012.
  1. Mar 25, 2012 at 5:56 PM
    undermoneyed
    undermoneyed [OP] aka Alley Opp,
    Mark
    B.C., Canada
    Tacoma TRD
    totally stock
    Is there a thread showing the installation of an after market backup camera?
    Mark
  2. Mar 25, 2012 at 7:52 PM
    jeratbp
    jeratbp Well-Known Member
    Jeremy
    Norfolk, VA
    '05 4Runner Sport V8
  3. Mar 25, 2012 at 8:00 PM
    stmpjmpr
    stmpjmpr Well-Known Member
    Jimmy
    So Orange County, Ca
    2014 Tacoma Sport MGM 4X4
    yes lots...do a search
  4. Mar 26, 2012 at 4:13 AM
    jeratbp
    Jeremy
    Norfolk, VA
    it's too bad no one has done the install and put up a Sticky! If I order the parts and try it myself, I'll post one but it might be awhile.
    Plus I have no experience with wiring!
  5. Mar 26, 2012 at 10:13 AM
    optimuspeterson
    optimuspeterson Custom User Title
    Germany
    08 DC SPORT 4WD
    DDX-512 BU Camera Kenwood 10" self powered sub Weather Tech mats BHLM Grillcraft Grill Reversed turn/parking
    Gents,
    I am not sure what you are looking for on the install. I ordered one of the license plate rear view camera's. Ran the wires through frame and secured with zip ties. Pushed wires through closest grommet/plug on drivers side to the dead pedal area.
    There is thread on here that shows the reverse lights wire that is in the bundle near the dead peddle (use this wire for turn on lead to the receiver). Run wires up underneath dash to receiver, and you are done. I believe it was a total of 3 wires, 1 power, ground, and RCA.
    Any questions, let me know.
  6. Mar 26, 2012 at 11:59 AM
    undermoneyed
    Mark
    B.C., Canada
    Tacoma TRD
    totally stock
    Thanks Optimuspeterson. I hate doing electrical but this sounds easy.
    Mark
  7. Mar 26, 2012 at 3:49 PM
    jeratbp
    Jeremy
    Norfolk, VA
    how about recommendations on which backup camera / display (mirror or lcd). I've seen the Peak, Boyo, and a few others but I have no idea which one is a decent buy with the CCD (instead of CMOS).
    also, I have no plans to put an aftermarket radio in.
  8. Mar 26, 2012 at 8:17 PM
    SWM
    SWM Well-Known Member
    Sean
    Ontario
    2006 TRD DCSB
    how did you power the camera ? new wires or tap into something in the back ?
  9. Mar 27, 2012 at 8:53 AM
    optimuspeterson
    Germany
    08 DC SPORT 4WD
    Not a 100% sure but I believe I used the reverse lights wire in the dead pedal area. Probably not the best answer (probably should have used relays..etc), but one that works.
  10. Mar 28, 2012 at 12:10 PM
    SWM
    Sean
    Ontario
    2006 TRD DCSB
    ok so you connected both the head unit "reverse" lead and the camera to the same wire ?
    i havent poked around under the truck since its been so crappy out this week. got all the stuff to do it just want to plan it out.
  11. Mar 29, 2012 at 11:23 PM
    sun
    sun Well-Known Member
    Memphis
    2011 PreRunner
    Pioneer avic-z130bt with axxess aswc and rear cam mod, audiovox 10 flip down monitor, Pyle pl76d headrest monitors, kicker cvr tens wired down to one ohm with hifonics Brutus 1200.1, Clazzio seat covers, 20% tint on front windows, polished factory exhaust, peragon retractable bed cover, pop n lock tailgate handle with dei actuators for automatic lock, viper 5901 alarm remote start with viper smart start, hid bixenon 4500k headlights with 4500k fog lights, led map license plate lights and dome lights
    Boyo makes good cameras they actually make them for a lot of factory's like Honda and some Toyota I think Ive installed a few boyos and they have yet to disappoint me I just bought one for my accord
  12. May 7, 2012 at 5:19 AM
    TonyPE
    TonyPE New Member
    Tony
    New Jersey
    2015 Gray 4x4 Access Cab
    I have a 2012 - no rear view camera, but it appears to have been pre-wired for one (or so I thought). I assumed that this would be a good spot to connect an aftermarket - can separate the connector (same one that has to be disconnected to allow the tailgate to be removed) and connect the license plate camera I bought. However, upon testing, there is no power to the connector when put into reverse. Anybody else ever use this method? Any success.
