After market lifts
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dougmays, Sep 11, 2008.
  1. Sep 11, 2008 at 11:23 AM
    dougmays
    dougmays [OP] Well-Known Member
    Doug
    Gainesville, FL
    2007 SR5 Tacoma 4WD/Tow Pkg Black
    Westin Bull Bar, Firestone Destination AT 255/70/16
    so i'm sure there have been plenty of posts about this
    but i was wondering what lifts people have been putting on there Taco's? Now also i dont know alot about what all goes into a lift....shocks? springs? struts? spacers?
    If i buy a "lift kit" will it have everything i need? I know the off road package comes with the blisten shocks (sp?) is this what most people buy? I'm only looking to lift 2-3". Also how much did you pay for lift?
    Also does this negatively affect gas mileage? I have a 07 DBL Cab, SR5, short bed, towing package, 4x4
    thanks in advance
  2. Sep 11, 2008 at 11:28 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Look at my pics I have basically the same truck. Yes it will neg. affect your mileage but only 1 or 2 points. Look into Toytec. Their kits as do most will come with everything you will need.
  3. Sep 11, 2008 at 11:32 AM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    you should talk to someone like a shop so that they know what you are trying to achieve with the lift you want, if your only trying to achieve a 2-3 inch lift then i suggest get the 5100's bilstein shocks you can achieve a 2.5" lift its cheap about 280 i believe from downsouthmotorsports.com, when you lift it will have an affect on mileage might not be much though.
