After-market rear wheel liners available?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Spacecoast, Mar 8, 2022.
  1. Mar 8, 2022 at 9:40 AM
    Spacecoast
    Spacecoast [OP] Well-Known Member
    2022 White SR5 2.7L
    Trailer wiring kit, hitch, seat risers
    So I recently purchased a new 2022 SR5 Tacoma with the 4 cylinder engine. My prior truck was a 2004 Ford Sport Trac with a 4.0 V6. One thing I've noticed is the "openness" of the rear wheel wells, which is somewhat disturbing considering the road grime and dirt that will accumulate under the vehicle. Do the higher trim levels have a better wheel well configuration? Is there aftermarket alternatives? Thanks in advance.
  2. Mar 8, 2022 at 10:07 AM
    JJ Diablo
    JJ Diablo Well-known member.
    JJ.
    CT
    2021 Cement TRD Sport Premium
    BOSS HTX Snowplow, Bilstein 5100s, Vled reverse light kit, Vled interior lighting, FitCamX dashcam, Timbren SES
    They are all the same. No larger liners for the rear from Toyota . The Trail and Pro are slightly lifted so those would have even more “openness” Nothing to worry about. Keep things clean especially if driving on salted roads. You will be fine. Its a truck and it will get dirty.
    As far as aftermarket, I have seen bigger liners avail for the front wheel wells. Not sure about the rear. Check HUSKY.
    Heavier duty benefits severe off roaders, the stocks work fine for the average driver.
  3. Mar 8, 2022 at 10:40 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Just wait till you get a few more miles on your truck and realize the stock liners warp and look like trash because there is nothing holding them on the front edge.
  4. Mar 8, 2022 at 11:46 AM
    Spacecoast
    2022 White SR5 2.7L
    Yeah I'm disappointed how thin and flimsy the wheel well liners are. About as thin as you can make plastic. Not what I expected.
