after market remote start causing engine fault P0705 (Park Neutral Switch)
Discussion in '1st Gen. Tacomas (1995-2004)' started by adependable, Mar 21, 2019.
  1. Mar 21, 2019 at 1:06 PM
    adependable
    adependable [OP] New Member
    Ken
    2004 Gold Toyota Tacoma
    After market remote start
    I have installed a aftermarket remote start in my 2004 Toyota Tacoma built a December 2003. it is causing engine fault P0705 (Park Neutral Switch) cannot figure out why?
  2. Mar 21, 2019 at 1:37 PM
    tony2018
    tony2018 Well-Known Member
    shouldn't happen, might wanna check your wiring and make sure you didn't tap into a wire you're not suppose to
  3. Mar 21, 2019 at 1:38 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    I'm not an expert in this realm, but I can tell you we'd need more info. What brand is the remote start, how did you wire it (were there instructions), etc...
    Can you start it manually? if you can, it's likely not wired properly. If you can't start it at all, then you may have shorted something during install.
    Search around here for the factory wiring diagram (or via google), don't get the Haynes or Chilton "wiring diagram" you need the factory one. Then you can start to trace the wires from the park switch on the shifter to where ever it goes.
  4. Mar 21, 2019 at 1:38 PM
    adependable
    Ken
    Agreed, we have double and triple checked. Reinstalled another one and are still getting the error. The remote start is a Excalibur
  5. Mar 21, 2019 at 1:40 PM
    tony2018
    i must be lucky, i got no errors. dets
  6. Mar 21, 2019 at 2:17 PM
    jbrandt
    Justin
    but does it start with the key/ignition?
  7. Mar 21, 2019 at 2:24 PM
    adependable
    Ken
    Yes, It starts all the way it should with or without the remote start. After about 100 mile the engine light comes on even after being reset. When I take out the fusses on the remote start, I have driven 350 mile and the error does not occur.
  8. Mar 21, 2019 at 2:40 PM
    tony2018
    I would like to know why you haven't posted any details on what this remote starter? It should even be this hard unless you did tap into the wrong wire, seriously. The remote start doesn't need to be connected to the transmission so why would your solenoid through false codes? All coming down to wiring.
  9. Mar 21, 2019 at 2:58 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    In any case your neutral safety switch has some how been bypassed the signal the ecm looks for
    With out a print of how things were done we are all guessing .
    Then it might be unrelated to the remote start
