After Market Shock?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tarheel54, Aug 4, 2017.
  1. Aug 4, 2017 at 1:47 PM
    Tarheel54
    Tarheel54 [OP] Well-Known Member
    2016 Tocoma 4x4
    Thought I throw this question to the whole forum after receiving no response on the towing thread. My question is does anyone have an informed recommendation to after-market shocks that may help solve my towing issue. I’m pulling a small single axle camper trailer, Rpod 180, with a GRVW of around 2900 lbs. I use a weight distribution anti-sway hitch and also have Super Springs Sumo Shock helpers installed on my SR5 4 x 4 truck. With all that I still get allot of “bounce” from the trailer and am thinking maybe upgraded shocks might solve the problem. Thoughts, recommendations, experiences, I’m all ears! Thanks….
  2. Aug 4, 2017 at 1:54 PM
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    Thought about airbags? Or a helper leaf?
  3. Aug 4, 2017 at 1:56 PM
    nDub
    Lead Free Gasoline
  4. Aug 4, 2017 at 2:18 PM
    Tarheel54
    2016 Tocoma 4x4
    Thanks, I'm using Sumo Ssprings, which are somewhat like airbags now. Looking more towards a solution of using better shocks if possible?
  5. Aug 4, 2017 at 2:26 PM
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Reformed Taco driver in a GX460
    You need a bypass shock with adjustable rebound. Bp51 or king, maybe Icon omegas.
  6. Aug 4, 2017 at 2:27 PM
    nDub
    Lead Free Gasoline
    I just reread your post... you mentioned your using the helper springs already. Oops.
    Anyway you can add more tongue weight? Add more load to your suspension?
    It seems the helper leaves would be enough but maybe they're not under enough load?
    As far as shocks go, I dunno. I think anything that is going to help your towing is going to make for a harsher ride when not towing.
  7. Aug 4, 2017 at 3:11 PM
    RIDERED67
    RIDERED67 Well-Known Member
    2017 TRD OFFROAD QUICKSAND, DCLB, TECH
    How about some adjustable air shocks? :notsure:
  8. Aug 9, 2017 at 11:51 AM
    Tarheel54
    2016 Tocoma 4x4
    That would work but been trying to avoid all the complications of dealing with air shocks. It's a pick'em'up truck not a tractor trailer truck! :D
    RIDERED67[QUOTED] likes this.
