After market tow mirrors
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Spit N Light, Jun 30, 2019.
  1. Jun 30, 2019 at 8:40 AM
    Spit N Light
    Spit N Light [OP] New Member
    2011 sliver Tacoma TRD
    I have replaced my factory side mirrors with after market tow mirrors. Every time I go to adjust the mirrors I blow the 7.5 amp fuse loosing clock,radio and mirrors I’m not sure what else that fuse runs but seems I loose everything. I bumped the fuse size up to a 10 and blow that as well any help or suggestions would be great thank y’all
  2. Jun 30, 2019 at 9:07 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    There's a short between the mirror adjustment switch and the mirror(s). Does the fuse blow when adjusting both sides or just one? I'd pull the door panel off and make sure you didn't pinch a wire.
  3. Jun 30, 2019 at 9:22 AM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    Or the motor is drawing too many amps.
  4. Jun 30, 2019 at 10:22 AM
    Spit N Light
    @vssman It will blow on either side. Right away as soon as hit the button.
    @ovrlndkull thats what I was thinking. But I’m not sure what I can do about it.
  5. Jun 30, 2019 at 10:23 AM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Return and say they aren't working as advertised need a new set.
    Skyway likes this.
  6. Jun 30, 2019 at 12:56 PM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    10 amps is a decent draw. If the mirror pulls more than that, then they must have a sizable motor in them.
  7. Jun 30, 2019 at 1:56 PM
    Skyway
    Skyway Well-Known Member
    Ande'
    St.Pete
    White 2009 regular cab
    SEND THEM TO:
    SKYWAY ANDE'
    ST. PETE FLA
    33703
    I don't power adjustable so they will work just fine... :thumbsup:
