After market towing equipment advice
Discussion in 'Towing' started by DPC, Jun 4, 2012.
  1. Jun 4, 2012 at 1:43 PM
    DPC
    DPC [OP] New Member
    02 Prerunner v6 TRD
    Need towing advice quickly
    I have an 02 Tacoma TRD 2wd Prerunner 6 cyl, automatic. Need to pull a 19 foot boat weight about 2500lbs, trailer weighs in at about 700 lbs. Getting mixed advice - told to get both tranny cooler and oil cooler in addition to hitch and electrical. Do I need both - longest tow would be about 2 to 2.5 hrs Boston to Sunipee NH. Should I also get brake controller? Getting contradictory advice on needing all of this, but rather safe than sorry. Also any advice on manufacturers of this equipment?
    Thought I'd ask the experts.
  2. Jun 4, 2012 at 1:55 PM
    Taco Guy11
    Taco Guy11 Well-Known Member
    Joe
    Western Maryland
    2011 TRD Sport
    5100's, Eibachs, Light Racing UCAs, ATO Rear bumper and ifs skid, Lights, Tonno Cover, TJM Front Bumper and Slider not sure of the brand.
    Does the trailer have electric brakes if so your going to need a brake controller. A hitch will be needed to pull the boat and you will need some sort of trailer wirings weather it be 4 pin or 7 pin. Transmission coolers are good to have when pulling heavy loads to help keep Trans temp down auto Trans week link is temp. As far as oil cooler I'm not sure I have actually heard people call the Trans cooler an oiler cooler but I'm not much help there. I pulled a 24' pontoon boat up a very steep grade an my truck didn't do bad at all I was impressed but I have the tow package.
  3. Jun 5, 2012 at 6:14 AM
    knucklehead
    knucklehead Well-Known Member
    Jeff
    Ottawa
    SR5 4x4
    Hitch, nav header
    I would say that you dont really need much. Obviously a hitch and wiring (I suggest factory trailer wiring, it is far superior to aftermarket t-connectors). You are on the edge of needing brakes. A brake controller by itself is of no use, since your trailer certainly hasnt got any brakes on it. If anything, get hydraulic surge brakes for the trailer, though youre on the edge of whether you really need it or not. transmission cooler would be a nice thing to have, but unless you go way higher, not needed. Just dont let it hunt for gears, set the tranny to 4 or 3 as needed to prevent hunting on steep inclines. Engine oil cooler is NOT required.
    Since youre going to be floating your boat in fresh water, you can go with non-stainless or stainless disk brakes, check out easternmarine.com for "tiedown" brand hydraulic surge brakes, galvanized vented kit is $398, ss drilled kit is $469. No controller needed. Just install the kit and go.
    Hint: if you dont want to mess around too much with reverse lockout wiring, also get a manual reverse lockout ball valve $16.
    I would absolutely NOT go with drum brakes, especially on a trailer that will be submerged. Electric brakes can also be problematic when youre dealing with water.
  4. Jun 5, 2012 at 2:48 PM
    Robertgeejr1
    Robertgeejr1 Well-Known Member
    Robert
    Aorora, Ill, yeah!
    1996 Toyota Tacoma SR5 4x4
    I have done all the hi-pro mods for a life time, since I got this truck at a great price, I will be happy with showroom new.
    if your not sure about anything, we used to sell to Dan Write, Write trailers in SeaKonk, Ma, right off of 95. he's got a big mouth, but he has a very large shop and know his shit.
    you better be sure about the brakes, Mass. is very strict on trailer requirements.
    usually when you get a boat of that size the trailer with it will have hyd srg. brakes.
    and thats a good load for the truck, I would see about getting the trans cooler, that would take some heat off also on the motor. if you have the time and money i would synthetic trans fluid and oil, they deal with the heat better.
  5. Jun 11, 2012 at 9:38 PM
    ToyComa84
    ToyComa84 Well-Known Member
    Matt(hew)
    "flatland"
    03 prerunner sr5
    plasti dipped wheel caps,
    i'm guessing you don't have the towing pkg on ur truck that would have already come from the factory with needed additional parts for towing? i'm no expert, but it sounds like with everything on ur truck it could tow up to 5k, but i don't know if the towing pkg would be necessary for that towing figure. so as Levar Burton used to say " '...but, you don't have to take my word for it.' "
  6. Jun 11, 2012 at 9:57 PM
    stewartx
    stewartx Well-Known Member
    Huntsville AL
    2012 Silver DC SB TRD Off-Road
    Winch, front hitch, step bars, bed extender, bed step, gull-wing toolbox, tailgate lock, security system, cb radio, etc.
    Okay, lets be realistic here. You're covering some distance (2 to 2.5 hrs of driving), pulling a load close to 4000-lbs with all your junk (fuel, boat gear, fishing gear, refreshments, or whatever) on board. Now add in the weight of yourself and possible passengers. You clearly need both coolers and the brake controller.
  7. Jun 12, 2012 at 5:05 AM
    knucklehead
    Jeff
    Ottawa
    SR5 4x4
    Hitch, nav header
    I hope you are trying to be funny. If you actually think that your bold words make sense, then I feel very sorry for you. He is only 500 pounds over the "bumper ball" towing limit for non towing package trucks. The difference falls well within the PAYLOAD allowance for his truck. As long as he isnt retarded regarding driving up inclines, there is absolutely no need for EITHER cooler. A brake controller is worthless, his trailer has no brakes, and it is a really moronic move to put electric brakes on a boat trailer. If he wants to install brakes, he needs hydraulic disk brakes, which have no need for brake controller.
  8. Jun 12, 2012 at 6:57 AM
    redz80
    redz80 Well-Known Member
    Brampton, ON
    Tacoma SR5 TRD 4x4 SWB
    Get a proper class 3 hitch, proper trailer wiring and go. you aren't driving in an F1 race so the coolers are nice but aren't nessessary. take it easy and drive at a pace you feel comfortable and enjoy your boat.
  9. Jun 12, 2012 at 7:40 AM
    stewartx
    Huntsville AL
    No, I'm not. I attempted to provide sound, reliable, advice. Nearly everyone recommends extra cooling when towing that amount of weight. I've had a transmission (on another vehicle) fry from heat while towing even less (though not much less) and have seen the engine temp climb many times while towing, so I certainly recommend extra cooling.
    As for the brake controller, he mentioned that (without asking which), so I assume he knows what is needed for his particular trailer. Many boat trailers have electric brakes, including my own. Finally, most state regulations require brakes to be fitted on boat trailers over 3,000 pounds. His boat & trailer exceeds that.
  10. Jun 12, 2012 at 8:07 AM
    redz80
    Brampton, ON
    If your engine temps are riseing while towing then you are driving to fast. As for the brakes if the trailer comes with brakes from the manufacture then you should oviously use them ....... towing is all about useing common sense and if you don't have that then buy a Volvo
  11. Jun 13, 2012 at 5:29 AM
    stewartx
    Huntsville AL
    Actually, in my case, it's usually the opposite. It's normally in slow traffic on a hot day when the temp guage starts to climb. Worst in memory was crawling along (repeated starting and stopping with the extra weight) in a traffic jam after traveling just over an hour on the freeway. Engine got darn hot that day. Just can't control what you're going to come across on the road.
  12. Jun 13, 2012 at 5:23 PM
    DPC
    DPC [OP] New Member
    02 Prerunner v6 TRD
    Thanks for all the info everyone. After a bit of additional calls and research it looks like I'll be able to get by with a class lll hitch, 4 pin wire and a transmission cooler - the latter is more as a precaution: you know $50 part vs $2500 transmission. The trailers I'm looking at have surge disc breaks so no need for a break controller. Thanks again.
  13. Sep 5, 2012 at 10:19 AM
    apierce7565
    apierce7565 I eat terrorism and crap freedom!
    Anthony
    Fort Bragg, NC
    2004 Toyota Tacoma SR5 4x4 standard
    ARB Safari snorkel, snug top, snug rug, yakima rack bars, ARB front bumper, plasti-dip camper shell windows, sway bar removal, turn signal reposition, led dome lights, recon smoke roof cab lights, 8000k xenon HIDs, 5100 Billy coilovers and rear shocks, tundra leafs, 3 inch lift rear shackles, 315/75-16 Bfg km2, 16"/8" Eagle Alloy 100 series black wheels, grey wire mod, deckplate mod, diff breather mod, Rola roof rack with tire carrier, trimmed front and rear fenders
    my transmission will get really hot while off roading and i have a manual...is it possible to install a cooler on it ot should i just not worry about it?
