After Market Wheel Bearing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2009Access4x4, Apr 7, 2023.
  1. Apr 7, 2023 at 2:32 PM
    2009Access4x4
    2009Access4x4 [OP] Well-Known Member
    Shane
    2009 Silver 4x4 access cab 6cyl
    Hey Guys,
    I need a new Rear Wheel Bearing on my driver's Side. I'm tempted to go with the Dorman after-market one since I'm really low on Cash right now. I found a shop that will install it for $350. Do you think the After Market will work well? Am I risking failure? Thanks!
  2. Apr 7, 2023 at 2:39 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    I generally dont trust Dorman for anything but nuts and bolts, or non-complex parts. For bearings look to DuraGo for high quality China parts. Maybe even TRQ stuff - I’ve never used their products but they seem to also use higher quality China parts.
    HondaGM and 2009Access4x4[OP] like this.
  3. Apr 7, 2023 at 2:42 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    OE. Buy once..
    steelcity2 and HondaGM like this.
  4. Apr 7, 2023 at 2:46 PM
    c4haskett
    c4haskett Active Member
    Charles
    2012 DCSB 4.0 Barcelona Red
    doorman will be fine. im running bearings from doorman and they were put on probably 50k miles ago. Im lifted with 12 wides as well so they get abused. Of course OEM is your best but i understand the low on cash part.
    2009Access4x4[OP] likes this.
  5. Apr 8, 2023 at 10:37 AM
    2009Access4x4
    Shane
    I had to go with Dorman since I’m in a time crunch. The shop broke the ABS sensor. Anyone know if the abs sensor is easy to remove or does this shop really suck? I’d like to be fair to them since the truck does have a lot of rust but I know shops don’t like to take responsibility for their mistakes either.
    HondaGM likes this.
  6. Apr 8, 2023 at 10:41 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Sometimes they can be stuck pretty bad..
  7. Apr 8, 2023 at 11:10 AM
    2009Access4x4
    Shane
    Ok. Just wanted to make sure they’re not at fault but I understand these things can happen.
  8. Apr 17, 2023 at 10:43 PM
    Wandering302
    Wandering302 Member
    I use Timken on everything, have never had an issue. Just replaced both rear axles on my Tundra 60k miles ago.
