After market wheels for TRD Package
Discussion in 'Wheels & Tires' started by MR. GRUMPY, Aug 24, 2011.
  1. Aug 24, 2011 at 5:34 PM
    MR. GRUMPY
    MR. GRUMPY [OP] Member
    MARK
    PHOENIX
    05 TACOMA PRERUNNER TRD
    Just got my 05 Tacoma Prerunner TRD OFF ROAD SR5 bout a month ago. Went to 4x4 shop here in Phoenix because I wanted to change my wheels to these really sharp PRO COMP Series 1069 wheels, I was told that you can not put after market wheels on a Tacoma with the TRD Package because with the TRD package the break drums are larger and will rub, talked to another tire shop and they said the same thing. You can only put after market 17'' wheels on with the 3'' lift, did not want to lift my truck after all the research shows that you will end up with some type of vibration. really po'd about not getting these new rims. Just vent'n.
  2. Aug 24, 2011 at 6:09 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    sounds like 4wheelparts.....
    do not go back there as a lift would have nothing to do w/ making the front calipers smaller. my sport came w/ 17" and i'm running 16" w/o changing anything to the brakes...as many others are doing. most all 17" are good as long as you get the right backspacing. some 16" will rub the calipers, but they are hit and miss.
  3. Aug 24, 2011 at 6:23 PM
    MR. GRUMPY
    MARK
    PHOENIX
    Yeah it was 4 Wheel Parts, so I JUST TALKED TO MY BUDDY WHO HAS 17'' ON HIS TRD SPORT PACKAGE, So go figure. I think I will talk to another shop and see what I need for the backspacing, I think the 4'' will be the best bet even though it will push the tire out a little it will keep it from hitting the control arms. we'll see
  4. Aug 24, 2011 at 6:26 PM
    The_Hodge
    SC
    if you are going to run 285's or below, 4.5"BS would be ideal.
  5. Aug 24, 2011 at 6:38 PM
    MR. GRUMPY
    MARK
    PHOENIX
    Thanks for the input Jamie, I'm check out this other 4 wheel place in Phoenix and see what they say.
  6. Aug 24, 2011 at 6:39 PM
    The_Hodge
    SC
    np, if you know exactly what you want, then 4wp usually has good prices. their knowledge and customer service both blow.
  7. Aug 24, 2011 at 6:40 PM
    MR. GRUMPY
    MARK
    PHOENIX
    The glass is half full my friend, just gotta find the right key for the right dam hole.
  8. Aug 24, 2011 at 6:43 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    TW>4WP for knowledge/ q&a
    good luck!
    :worthless:
    when you're done!
