After only 500 miles. Knocking coming from drivers side
Discussion in '3rd Gen. Tacomas (2016-2023)' started by fergie059, May 24, 2020.
  1. May 24, 2020 at 5:09 PM
    fergie059
    fergie059 [OP] Member
    2020 Offroad
    its probably been covered here,yes I did a search,and never found any answers. Driving back from a short trip Saturday,my truck suddenly started making a rythmic knock from what sounded like the drivers side front. I couldn’t pull over right away ,so after a couple of miles ,it did go away,but I can’t imagine any serious issues on a 500 mile truck. It’s an OR. Any help would be appreciated. It definitely sounded like it was in the driveline as it got faster when I accelerated
  2. May 24, 2020 at 5:35 PM
    JNG
    JNG Shitposter extraordinaire
    2019 Silver TRD OR DCSB 4x4 AT P&T
    At times the 3.5 liter sounds like a diesel engine. That's normal. The injectors have a cleaning cycle that is rather loud at times. However if it is more than a loud ticking noise I would cease operation and call your dealer. While I won't say the 3.5 is an example of Toyotas typical bombproof engines, it is a proven, reliable, and durable engine (although it has it's quirks). A video if you can post one would be great.
  3. May 24, 2020 at 5:38 PM
    pochoboy
    pochoboy Well-Known Member
    idk, maybe something was stuck on your tires thread? and freed itself after a few miles
    Kev250R, Junkhead, BSFord and 3 others like this.
  4. May 24, 2020 at 5:48 PM
    fergie059
    2020 Offroad
    The sound was quite a bit heaverier than that. Almost like a cv joint. But it did go away.
  5. May 24, 2020 at 7:43 PM
    desmodue
    desmodue Unsprung member
    2016 TRD OR AC
    CV joints don't heal themselves. The injector cleaning cycle won't kick in at highway speeds. It could be a number of things, but just for shits and grins look at the roof of your truck, is one of the roof moldings loose or missing? Pretty common for them to come loose especially if you run thru automatic car washes.
  6. May 25, 2020 at 3:25 AM
    JNG
    Yes, the injector cleaning cycle only occurs at low idle. That said "ticking, tapping, knocking, and clatter" are very common complaints in reference to the 3.5 v6. This noise occurs not only at idle but through out the majority of the RPM range. Most of the noise can be traced back to the injectors and high pressure fuel pump. Both of which seem to be rather noisier than average. Hence my "sounds like a diesel" comment. Drive under a bridge with the windows rolled down ( or similar conditions where an echo can occur) and you can hear the clatter. I'm surprised the OP could not find anything during a search as this forum and others has many threads on this sort of noise.
  7. May 25, 2020 at 3:46 AM
    fergie059
    2020 Offroad
    I’ll call the local service dept,and take it in. But it’s like going to the dentist. It hurts until you get there. It’ll be practically impossible to diagnose unless it does it while it’s there. I’ll keep you guys posted. Thanks
  8. May 25, 2020 at 4:02 AM
    Thegenerik1
    Thegenerik1 Well-Known Member
    Erik
    NorCal
    18 DCLB OR
    Did you try opening the door?
    Phlogiston likes this.
  9. May 25, 2020 at 4:20 AM
    fergie059
    2020 Offroad
    No,I was in the middle lane of 6. Traffic was insane,when it started. It sounded like a metal to metal situation,almost the cv joint had 2 million miles on it. When I sped up ,so did the knocking,finally ,after a couple of miles,I got to the point where I could pull over,and inspected all I could on the side of the highway. I didn’t see any marks,or wear places,so I got back in it ,and pulled away,it started again,but after a mile or so,it went away,and I finished the drive home( probably another 75 miles). I took it out yesterday to the gas station to fill it up ,I drove it maybe 5 lies or so,all was quiet. Stay tuned
  10. May 25, 2020 at 5:14 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Doesn't sound like anything thats normal to me. I've never heard any unusual knocking noises from my 3.5 when that new. Yes, the direct fuel injection is a bit noisy at times compared to other fuel injection systems, but i've not heard any dull type knocking.
  11. May 25, 2020 at 5:41 AM
    01Snake
    01Snake Fast Car Junkie
    SATX
    2020 White TRD Sport DCSB 4X4
    Ugh. This is not what I wanted to hear as I'm seriously considering picking up a Tacoma. After having a 3rd gen (V6) and 4th gen (V8) 4Runner, I moved over to a 2011 Limited. After having the car for about a month, I started hearing a diesel sound while sitting at idle with the car in drive or at low speeds. While faint, I still became fixated on the noise and it drove me nuts! Duh..Duh..Duh...Duh sound. I took it to Toyota several times and was told is was normal as you said. So after less than a year, the redesigned 2014's came out and I dumped the 2011 for a brand new Trail Premium with KDSS and everything. Test drove it and didn't hear the noise. After having the car a few weeks, I started hearing the noise again. Traded it in on a JKU Rubicon Hardrock a few months later after changing jobs and not needing a daily driver SUV anymore.
    If the Taco engine sounds like the 4Runner one, guess I may have to cross it off my list. It probably doesn't bother most folks but somehow I could always hear it even with the radio on and it literally annoyed the hell out of me. Better take several test drives to see if I hear it before taking the plunge. :(
  12. May 25, 2020 at 5:48 AM
    MannyS
    MannyS Well-Known Member
    Republic of Texas
    Tacoma engines sound like a sewing machine from day one.
    Junkhead likes this.
  13. May 25, 2020 at 6:06 AM
    mhornco
    mhornco Well-Known Member
    Also possible you just picked something up from the road and it came out after a bit. Could have been a rock or piece of something else, even a screw or nail that stuck for a bit but came loose. You won't hear any of the injector stuff at highway speeds
  14. May 25, 2020 at 6:29 AM
    zoo truck
    None
    As
    As far as hearing those type noises even with the radio on, engine's been never that loud that i can hear them. The engine/exhaust tone does get pretty loud when revving over 2500 rpm's up grades.
  15. May 25, 2020 at 6:41 AM
    01Snake
    SATX
    It was a really weird issue. The sound was not very loud but was very noticeable inside the car. Would only happen at idle in drive and would go away once the RPM's climbed. After both 4Runners made the exact same noise, it's clearly a normal characteristic of the Toyota engines as others have said. All other Toyota/Lexus cars I have/had are V8's with the exception of my MKIV TT Supra which is a V6 but the noise that makes doesn't annoy me. :D
  16. May 25, 2020 at 7:13 AM
    Pilsner
    Pilsner Well-Known Member
    18 TRDOR
    255/85r16 ST Maxx 6112/5160 w/ Dakar RCI armor, sliders, and rear bumper CBI hidden winch mount w/ Smity 20k
    Check all your lug nuts.
    fergie059[OP] and Skydvrr like this.
  17. May 25, 2020 at 7:21 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Um, maybe a dumb question, but you aren't driving around on pavement with 4WD switched on, are you?
    whatstcp and Skydvrr like this.
  18. May 25, 2020 at 7:34 AM
    OilCapital2021
    OilCapital2021 Well-Known Member
    Brent
    Houston, TX
    ‘19 Cement DCSB OR
    CBI Sliders; Mobtown Skids; Prinsu Rack; BD Lights; Voodoo/MAX Bed Rack; Tepui RTT; MESO stuff
    +1 on this, these roof moldings slapping when loose make really loud and confusing sounds. Like a very loud knocking noise that you will hear over radio and it comes and goes depending on the crosswind direction, so it could explain your inconsistency of happening. Check them, it's a 5 second thing (step on running board and look at the black trim on top of roof, if it's loose you'll notice).
    It happened to me while on a trip across the country from Nashville to Vermont and I was convinced it was coming from drivers side front, even causing me to pull over in the median of the freeway and crawl under my drivers side to try and figure out what was going on. But I eventually figured out it was the driver's side top roof molding coming loose and slapping in crosswind. FYI I never used an automatic car wash, and I have a 2019 OR.
    Good luck!
    fergie059[OP] and AKGSD like this.
  19. May 25, 2020 at 7:42 AM
    TacoPharm
    TacoPharm Follower of Jibbers Crabst
    Phil
    San Diego
    MGM 2017 Tacoma TRD Off Road 4x4
    SPC Light Racing UCA Eibach Pro-Truck Lift System Deaver Stage 1 Leafs Wheelers Superbumps x4 Wheelers U-bolt Flip Kit SCS Ray10 16x8 Gun Metal 285/75/r16 BFG A/T KO2 CMC by @Speed Freek 4.88 Gears CBI Alu Full Skids Sliders by @Shmellmopwho SOS Concepts Streamline Bumper Warn Xeon 10-S winch Factor 55 Flatlink E recovery shackle Optima Red Top 35 @Coupe “TRD” Batt. Hold down Baja Designs Squadron SAE Fogs Caliraised Ditch lights Hypertech Speedometer corrector Fend-X inner fender guards ARE Z-Series Topper DYI sleeping platform
    The inner splash guard on my drivers side comes loose all the time, and at highway speeds knocks the inner fender wall, it’s rhythm also increases and decreases depending on speed, and can be heard when the radios is at a comfortable volume too.
  20. May 25, 2020 at 7:42 AM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    This isn't a Toyota issue, it's a what all new engines do. Go to a Honda dealer and listen to the racket A ridgeline or pilot make. Cleaning cycles are the norm nowadays.
