After suspension upgrade, what other parts need strengthening?
Discussion in 'Suspension' started by Tahoebroccoli, Dec 28, 2020.
  1. Dec 28, 2020 at 5:40 PM
    Tahoebroccoli
    Tahoebroccoli [OP] New Member
    2020 Cement Taco TRD
    First time posting here.
    Bought this kit a few weeks back:
    https://accutuneoffroad.com/product/05-tacoma-mid-travel-suspension-kit-stage-4a-king/
    I am nearly ready to install, just waiting on the UCA's. I have been told by some that I need to upgrade 1) tie rods 2) sway bar linkage 3) steering knuckles/spindles with a weld on gusset if I am going to run this set-up. FYI I am planning on running 2.5" lift in the front, if that makes a difference.
    My Question:
    Do I really need to upgrade any of this? If I do, which of these parts should be my top priority? Is there something else, not listed, I should focus on?
    In addition, I have been told that if I am to upgrade the sway bar linkage, I should look into detachable links for off-roading. Worth it?
    Thanks in advance. This is my first real suspension build and I want to do it right.
    Key-Rei likes this.
  2. Dec 28, 2020 at 5:44 PM
    yaaj2005
    yaaj2005 Well-Known Member
    Fang
    Sacrament, CA
    2014 Toyota Tacoma TRD
    No you do not at the moment... That some be they complete set up... A lot of people run without those upgrade for the longest time... The question is what do you plan to do?
    sbx22 and Tahoebroccoli[OP] like this.
  3. Dec 28, 2020 at 5:48 PM
    Tahoebroccoli
    I plan on doing light off-road stuff, mostly BLM roads with the occasional Moab and Canyonlands trails (nothing difficult, though). I like to do some fast driving on those desert roads, but never anything above 55mph.
  4. Dec 28, 2020 at 5:59 PM
    yaaj2005
    Fang
    Sacrament, CA
    In your case then doing the steering knuckles/spindles welded gusset is a plus.... other upgrade you can slowly do it...
    fatfurious2 and Key-Rei like this.
  5. Dec 28, 2020 at 6:08 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    If you plan on driving fast, I would install cam tab gussets and spindle gussets at a minimum.
  6. Dec 29, 2020 at 6:14 AM
    reg0928
    reg0928 Well-Known Member
    Ross
    Crestone, Colorado
    05 TRD OR Access Cab
    3"OME, 255/85R16
    I'd do cam tabs and spindle gussets before you start mobbing down desert roads. Maybe better bump stops too. I'd also throw the sway bar in the trash.
    None of those upgrades are completely necessary for light off roading though
    yaaj2005 and Key-Rei like this.
  7. Dec 29, 2020 at 7:35 AM
    EvilElvis
    EvilElvis Well-Known Member
    PNW
    2012 3wd
    You won't need to reinforce the swaybar linkages if you don't run a swaybar. I ditched mine when I upgraded my suspension. I agree that cam tabs should be upgraded. As for the stuff OP listed, unless they are completely shot you don't really need to upgrade them for the driving you described.
    Jukeboxx13 likes this.
  8. Dec 29, 2020 at 11:23 AM
    CadCamMan
    CadCamMan Well-Known Member
    Mission Viejo, California
    2011 DCSB, 4WD TRD OR, 2.5 Kings
    TRD SC, suspension
    I have the same kit with SPC UCAs and the Tundra rears.
    No, you don't need any of those upgrades. If you have a tendency to hit rocks with the sides of your front wheels then a spindle gusset may be suggested. I have yet to bend a spindle, but my truck is the only vehicle I have so I'm careful when I'm wheeling offroad. In all of the posts I've seen concerning bent spindles, the owners either abuse their trucks or hit immovable objects, like curbs.
    Enjoy your new suspension, I love my kit.
    yaaj2005 and SpeySquatch like this.
  9. Dec 30, 2020 at 8:12 AM
    yaaj2005
    Fang
    Sacrament, CA
    I totally agree with you guys... if you can weld the gusset and cams tab your self go for it... it a cheap mods, doesn't cause a arm and leg to do... it will just give you some piece of mind..
  10. Jan 3, 2021 at 8:37 PM
    Jukeboxx13
    Jukeboxx13 Well-Known Member
    California
    2017 TRD OR DCSB 4x4
    the most inportant thing imho is the needle bearing. It needs to be swaped out for the ecgs when doing any type of lift or it can blow into your front diff. All the other stuff you mentioned will last so long as your not jumping your truck and doing stupid shit.
  11. May 25, 2024 at 2:10 AM
    brendoz
    brendoz New Member
