After U-Bolt Retorquing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by APynckel, Nov 24, 2019.
  1. Nov 24, 2019 at 5:54 PM
    APynckel
    APynckel [OP] Well-Known Member
    2018 MGM Tacoma TRD OffRoad 4x4 DCSB
    Bakflip MX4 Tonneau Cover XenonDepot ExtremeHID w/ Phillips bulbs
    so I took each side completely off (bracket, pillow, ubolts, nuts, washers) to give everything a proper cleaning to ensure there wouldn't be any sand / dust / mud between the ubolts and springs (and axle - mount). I torqued everything down to 70 ft lbs with some blue loktite. Do I now need to get an alignment? Everything in my mind is screaming yes.
  2. Nov 24, 2019 at 6:05 PM
    baldbeardedtaco
    baldbeardedtaco Well-Known Member
    FL
    18 TRD Sport DCSB MGM
    I’m no expert but no. The rear is a solid axle meaning no rear alignment at least from my reading/understanding
    Big tall dave likes this.
  3. Nov 24, 2019 at 6:07 PM
    APynckel
    But I have just added in some variation that might not have been controlled by the sway bar, shocks, and other misc items.
  4. Nov 24, 2019 at 6:09 PM
    Stoked
    Stoked Not So Well-Known Member
    Jeff
    Celina, Tx
    2016 DCSB TRD OR
    You can get one for your own peace of mind, but it's not necessary.
  5. Nov 24, 2019 at 6:10 PM
    baldbeardedtaco
    FL
    Like I said I’m no expert but what I’ve read is a solid rear you can’t perform an actual rear alignment. Sway bars and shocks don’t effect an alignment front or rear to my understanding
    AKGSD and SR-71A like this.
  6. Nov 24, 2019 at 6:12 PM
    APynckel
    Then how is toe controlled?
  7. Nov 24, 2019 at 6:16 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Only in the front. If you do anything to the rear, you dont need an alignment. Also, no rear sway bar unless you added one
    SR-71A likes this.
  8. Nov 24, 2019 at 6:16 PM
    baldbeardedtaco
    FL
    It’s not, unless someone mentions otherwise
    edit: we are talking about the rear correct?
  9. Nov 24, 2019 at 6:18 PM
    baldbeardedtaco
    FL
    Thanks for confirming. I’m not a expert nor have personally experience/knowledge so I didn’t want to say with 100% certainty
  10. Nov 24, 2019 at 6:18 PM
    APynckel
    yes.
  11. Nov 24, 2019 at 6:21 PM
    CLVol1255
    CLVol1255 Well-Known Member
    Tennessee
    2017 TRD Sport DCSB
    Bilstein 8112/8100 ICON RXT Stage 2 JBA UCAs Archive Garage HH w Shackles Archive Garage U Bolt Flip kit Nitto Ridge Grapplers 255/80/R17 TRD Front Skid and RCI Transmission Skid Kenwood DMX 1057XR Head Unit Focal Utopia WM 3 way plus WM10 Sub Mosconi 5/30 and Genesis Dual Mono Amp
    No rear alignment needed
  12. Nov 24, 2019 at 6:22 PM
    fatfurious2
    David
    Ashburn, VA
    Also being said, when you do get an alignment, since you only need a front end, the place should charge you accordingly. Aka dont pay for a 4 wheel alignment, when they can only do the front
    Grossomotto and SandyTaco4x4 like this.
  13. Nov 24, 2019 at 6:23 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I agree with what David is saying and will also confirm you absolutely do not need an alignment.
    fatfurious2 likes this.
  14. Nov 24, 2019 at 6:23 PM
    baldbeardedtaco
    FL
    They can be snakes
  15. Nov 24, 2019 at 6:26 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Alignment is fine...
    On the other hand, 70 ft-lbs on lubed threads when it specifies 52 ft-lbs on dry thread, after they've already been torqued to yield...
    shakerhood and Lt. Dangle like this.
  16. Nov 24, 2019 at 6:29 PM
    baldbeardedtaco
    FL
    I thought I read there was still confusion of the torque on the ubolts. Some say 1 some say others. Ie. going off .2nd gen numbers and the others think the torque listed as spec is a misprint
  17. Nov 24, 2019 at 6:30 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    You have compromised the integrity of the rear end and have now deemed the truck entirely unsafe to drive.
    I would junk the truck.
  18. Nov 24, 2019 at 6:37 PM
    fatfurious2
    David
    Ashburn, VA
    I think what you're referring to is 37 vs 73 ft-lbs (as the misprint)
    70 is good, but id also recheck after a couple hundred miles.
  19. Nov 24, 2019 at 6:38 PM
    baldbeardedtaco
    FL
    ok yes that was it.
    But where did 52 come from?
  20. Nov 24, 2019 at 6:40 PM
    fatfurious2
    David
    Ashburn, VA
    52 seems low to me. So i don't know where it came from.
    Without looking it up, id automatically think in the 80-85 ballpark. I just happened to remember the misprint because i was working on my friends truck recently
