Aftermark Headlight Install Issues
Discussion in '2nd Gen. Tacomas (2005-2015)' started by justwhat21, Sep 27, 2023.
  1. Sep 27, 2023 at 6:11 AM
    justwhat21
    justwhat21 [OP] Member
    2007 Tacoma PreRunner
    I bought a set of aftermarket headlights and the installation went fine with the exception of one connector. In the attached picture, the connector does not work with the connector provided by the headlight mfg. The alignment grove is on the opposite side.
    Has anyone else run into this issue? Any suggestions on how to fix this? I am currently looking into purchasing a new connector. Or possibly grinding off the alignment tab to make this work. Any other suggestions are greatly appreciated.
  2. Sep 27, 2023 at 9:29 AM
    RockfordTaco2006
    RockfordTaco2006 Well-Known Member
    Alexander
    2006 Toyota Tacoma TRD Off Road 4x4
    2 Inch Lift
    Yikes.....how does that happen? I dont think I'd trust it. Where did you buy these headlights? Can you return them because of this?
  3. Sep 27, 2023 at 10:25 AM
    justwhat21
    I purchased the headlights from eBay. Perhaps not the greatest idea? I have contacted the seller and they don't know why it doesn't have a matching connector either. They will accept a return though.
    They seem to work well though. I can't seem to figure out what this connector does since I have full functionality of the lights.
    Even though I can return them, I wanted to see if there was some way to fix the issue first.
    RockfordTaco2006 likes this.
  4. Sep 27, 2023 at 10:32 AM
    Revelations
    Revelations Well-Known Member
    2014 MGM DCSB
    That looks like it's for the side markers.
  5. Sep 27, 2023 at 10:48 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    I just did my sons 09....if i remember correctly it had the headlight connector..one for DRL's/Turn signal and one for sidemarker light
  6. Sep 27, 2023 at 10:56 AM
    justwhat21
    That would make sense that they are side marker lights since my turn signal lights work. I did not notice that they were not illuminated. I will double-check this tonight.
    I'm considering removing the alignment tab and seeing if they work. Is this a bad idea? Or worth a shot?
  7. Sep 27, 2023 at 5:28 PM
    justwhat21
    I confirmed that these lights are for the side marker lights, however, I still can't seem to make any sense of why they are different than OEM. The attached image shows both the OEM lights and the new sockets for the LED connector. You can see the alignment tab is on the opposite side like I mentioned previously. The pins of the connector looks the same, so I trying to think why cutting the alignment tab off wouldn't fix the issue. They should work. I just want a second opinion or someone to talk me out of it. Any thoughts?
  8. Sep 27, 2023 at 5:34 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Meh, I'd just file down the alignment tab and send it. It's not like they're nice OEM lights..
    HondaGM and Dm93 like this.
  9. Sep 28, 2023 at 6:04 AM
    justwhat21
    Thanks for all the advice. I got antsy last night and cut the tab off one side and it worked. Not sure if this will lead to problems later on, but it's just a small LED and I'm not too worried about it. I just didn't see the justification for buying additional connectors for aftermarket headlights I bought through ebay. We shall see what happens.
    Revelations likes this.
  10. Sep 28, 2023 at 6:24 AM
    Revelations
    2014 MGM DCSB
    That's what I would have done too. As long as the connector clicks in place, the alignment tab isn't that necessary.
  11. Nov 17, 2023 at 7:45 AM
    shredddogg
    shredddogg New Member
    Everett
    '07 black tacoma SR5 super long
    after market grille, ready lift leveling kit, front diff drop, home made airaid intake, sumo springs rear, borla cat-back exhaust
    where did you get those shorter connectors? i recently got new headlights from ebay and my side marker connectors are too long to fit in the housing and seal.
  12. Nov 20, 2023 at 12:27 PM
    9kfever
    9kfever Well-Known Member
    Cheap headlights. Save yourself now and teturn
  13. Nov 20, 2023 at 12:34 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    It's just two wires. Filament bulbs don't care about polarity. Some LED bulbs do, in which case you just flip the bulb in its socket.
    eBay is usually the least expensive place to buy aftermarket headlights and tail lights. :notsure:
