Aftermarket 16” wheels
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Signatureinc, Mar 9, 2022.
  1. Mar 9, 2022 at 2:14 PM
    Signatureinc
    Signatureinc [OP] Well-Known Member
    Doug
    Flat Land, Ontario
    2019 TRD OR Access Cab
    Hi everybody, looking for an old thread and or some pictures of AFTERMARKET 16” wheels and tires on a 3rd Gen no lift. I’m looking at 0 offset 16’s on Duratrac 265 70r16
  2. Mar 9, 2022 at 3:33 PM
    avn
    avn Well-Known Member
    A
    CA
    2022 TRD OR
    EDIT: there is a “show your Tacoma’s with no lift” thread somewhere though, I’d try google searching instead of searching on the forum
    Hey man, I’m on FN FX pros 16x8 et0 with 265/70r16 general grabber ATx, no lift everything else stock.F52C9BA3-327F-4A52-8993-825B317B920E.jpg390A76A1-4E07-4D98-8E02-63EAAB3BC929.jpg AB13A448-0D10-4442-9E5B-133A41A8C4F7.jpg
  3. Mar 9, 2022 at 5:07 PM
    Signatureinc
    Doug
    Flat Land, Ontario
    You mostly see upgraded tires but on stock wheels. I like your set up a lot could even put a 20-25mm spacer on there. Thanks man love it !
  4. Mar 9, 2022 at 5:09 PM
    avn
    A
    CA
    2022 TRD OR
    Thanks, you def could put spacers if you’d like. I am not trying to have a lot of poke, I actually wanted slightly less but it’s really tough to find hubcentric 16x8 et10s that look good. I’m stoked with how these came out though
  5. Mar 9, 2022 at 5:13 PM
    Otterstuff
    Otterstuff Well-Known Member
    2022 White SR5 Access Cab 4WD V-6
    Tube steps, Vision Turbine wheels, bug deflector, seat covers, and tonneau cover
    I've been looking also. The only aftermarket wheels that I have found, in 16", are all black. I'm looking at buying the dark gray alloy wheels from Toyota. The center caps are extra.
    Signatureinc[OP] likes this.
  6. Mar 9, 2022 at 5:17 PM
    Signatureinc
    Doug
    Flat Land, Ontario
    Why did you decide to stick with 16”?
  7. Mar 9, 2022 at 5:18 PM
    avn
    A
    CA
    2022 TRD OR
    EDIT: “this guy” = the FN wheels guy. His wheels also come with the center caps.
    send this guy an email he’s pretty quick, tell him what you’d like and he can send you pics and whatnot. He sells the wheels I got in a gun metal (for some reason this model isn’t on their site), could be close to what you’re looking for. Also, see:
    https://www.fnwheels.com/store/product/konig-countersteer-offroad/
    ceh527 and Otterstuff[QUOTED] like this.
  8. Mar 9, 2022 at 5:18 PM
    Signatureinc
    Doug
    Flat Land, Ontario
    Finding any 16’s is challenging but I’m looking at matte black with some silver studs but not a lot to choose from
  9. Mar 9, 2022 at 5:19 PM
    Otterstuff
  10. Mar 9, 2022 at 5:22 PM
    avn
    A
    CA
    2022 TRD OR
    Just wanted to keep my truck as stock as possible, it’s my daily driver and it’s capable enough for the kind of off roading I like to do. Mostly just taking my dog somewhere or fuckin around in the woods during firewood cutting season
  11. Mar 9, 2022 at 5:23 PM
    avn
    A
    CA
    2022 TRD OR
    I’m assuming by studs you mean lug nuts? If so you can just buy the correct spec lug nuts in the color you’d like.
  12. Mar 9, 2022 at 5:37 PM
    Signatureinc
    Doug
    Flat Land, Ontario
    I’m the same I don’t want it hard core OR but want to beef it up a little.. lol ya chrome or silver lugs maybe?
  13. Mar 9, 2022 at 5:39 PM
    eurowner
    eurowner Duke Sky
    Scoty
  14. Mar 9, 2022 at 5:40 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Those aren't aftermarket!
  15. Mar 9, 2022 at 5:42 PM
    eurowner
    eurowner Duke Sky
    Scoty
    They are not OEM manufacturer installed on the 3rd Gen!
    :fistbump:
    JasonLee[QUOTED] likes this.
  16. Mar 9, 2022 at 5:43 PM
    avn
    A
    CA
    2022 TRD OR
    Take what I’m saying with a grain of salt, but if you’re similar to me (no crawling, no high speed off roading, no insane rubicon type trails or mudding or any of that sort), then the best upgrade you can do is a nice set of tires and you’re good to go. I bought the wheels for the appearance and the ones I got happened to also be lighter than the stock wheels, so that was a plus. I bought this truck for reliability. Any modifications I add to the truck will change the performance and reliability (mostly and inverse relationship) and like I said the performance out the door is plenty for me as is.
  17. Mar 9, 2022 at 5:47 PM
    taco0315
    taco0315 Member
    PA
    2013 Honda Pilot Touring
    Method 305 NV Machined - 16x8 0 offset. New tires are coming soon.
  18. Mar 9, 2022 at 5:51 PM
    Signatureinc
    Doug
    Flat Land, Ontario
    Nice! Love the red !!!
  19. Mar 10, 2022 at 6:08 AM
    Chocaholic
    Chocaholic Well-Known Member
    These are 16x8 (0 offset) FN FX Pro’s with stock tires, sensors and no lift. And...not black:
    Otterstuff[QUOTED] and mallege like this.
  20. Mar 10, 2022 at 9:00 AM
    AMMO461
    AMMO461 TACO/FJ/FJ
    SoCal Hi-Desert
    2021 TRD Off Road DCSB OD
    What center caps did you go with, they don't look like the stock Method's. Got a close up pick?
