Aftermarket 16x8 wheels don't fit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wyattg99, Nov 21, 2016.
  1. Nov 21, 2016 at 10:07 AM
    wyattg99
    wyattg99 [OP] Member
    Wyatt
    Colton
    05 Tacoma SR5
    Hi all, I ordered some 16x8 allied daytonas last week and they don't fit over my calipers. I was wondering if anyone knew why they wouldn't fit because the sr5's come stock with 16s. Any help is much appreciated thanks!
  2. Nov 21, 2016 at 10:13 AM
    lawrenccar1
    lawrenccar1 Well-Known Member
    Springfield, Virginia
    2015 4x4 DCSB TRD Off-Road
    offset of wheel incorrect..
  3. Nov 21, 2016 at 10:40 AM
    wyattg99
    Wyatt
    Colton
    05 Tacoma SR5
    That's why the wheel won't fit over the caliper?
  4. Nov 21, 2016 at 10:41 AM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    What's the offset?
  5. Nov 21, 2016 at 11:24 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    There's a lot of 16" wheels that wont fit over the calipers. Inner diameter of wheel can be too small or the offset of the wheel may bring the sides of the wheel too close to the caliper.
  6. Nov 21, 2016 at 7:19 PM
    wyattg99
    Wyatt
    Colton
    05 Tacoma SR5
    0mm offset
  7. Nov 21, 2016 at 7:33 PM
    Team Flatline
    Team Flatline Not squatin' w/ my spurs on...
    Eric
    Up a creek, Fla
    PreRunner
    Maxtrac'd, Icons, Dakars...........
    Wyatt, are the tires mounted to the new wheels? If so, are the wheel weights the tape on kind on the"inside" of the wheel? Do your back wheels go on just fine? I had the same issue with my American Racing wheels with the "tape on inside" wheel weights. You might check that first.
  8. Nov 21, 2016 at 8:11 PM
    wyattg99
    Wyatt
    Colton
    05 Tacoma SR5
    Those are stock wheels. And we didn't use tape weights. Yes they fit on the rear just fine. I've ran 15's on the rear before
  9. Nov 21, 2016 at 8:12 PM
    wyattg99
    Wyatt
    Colton
    05 Tacoma SR5
    What American racing wheels? I'm trying to find some steelies to put on
  10. Nov 21, 2016 at 8:14 PM
    WATaco
    WATaco Well-Known Member
    Ed
    Seattle-ish, WA
    '14 Tacoma ORD
    Leer, AllPro sliders, Prinsu, OME, JBA UCA
    they fit on the rear because the trucks have drum brakes. they don't fit on the front because of the calipers. make sure when buying wheels for a taco that they are designed to fit a taco, and even then you may get a miss - my first rim for my spare would not clear the calipers, so it was sent back for a different one which did.
  11. Nov 22, 2016 at 5:31 AM
    lawrenccar1
    30mm is the factory offset for the 16" wheel
  12. Nov 22, 2016 at 8:55 AM
    wyattg99
    Wyatt
    Colton
    05 Tacoma SR5
    So a 16x8 with 30mm of offset would most likely work?
  13. Nov 22, 2016 at 9:08 AM
    gnardoggie
    gnardoggie Well-Known Member
    I had the same issue with my Methods, but a small spacer and extended thread lugs fixed the issue. I don't do any super crazy crawling, but some people might be against this recommendation depending on your use.
  14. Nov 22, 2016 at 11:32 AM
    moondeath
    Pa, Gardners
    Not necessarily. The inside diameter of the wheel is important. If its too small, then it wont fit over the caliper. You need to find wheels that are specifically going to fit the Tacoma if youre going for 16".
  15. Nov 22, 2016 at 11:40 AM
    JadedTaco
    JadedTaco Well-Known Member
    IA
    15 OR SSM (MT)
    Lift, tires, mats, blah, blah, blah...
    WATaco likes this.
