Aftermarket Backup Camera Location + Install
Discussion in '2nd Gen. Tacomas (2005-2015)' started by belone12, Mar 31, 2014.
  1. Mar 31, 2014 at 4:53 PM
    belone12
    belone12 [OP] Well-Known Member
    Brian
    Long Island, NY
    06 Tacoma Double Cab 6spd TRD OR
    Bilstein 5100s, AAL, heated leather seats, Thule Rack, tow package, anytime foglight, Fold-a-cover
    Hey Guys,
    Going to install my backup camera this weekend. (Not in the tailgate handle). Anyone have a reason why I shouldn't mount it where I mock taped it in the picture or have a suggestion for where? The tow hitch is somewhat limiting to mounting locations, so i was just going to thru-bolt it to the hard plastic so it is still near center.
    I am also going to silicone it and flat black it so it doesn't stand out as much.
    If you have a camera mounted on yours (not tailgate handle) feel free to post it here because I had a hard time finding any pics while searching.
    This is the camera..
    http://www.amazon.com/gp/product/B0...pf_rd_t=101&pf_rd_p=1688200382&pf_rd_i=507846
  2. Mar 31, 2014 at 4:54 PM
    belone12
    Brian
    Long Island, NY
    Reserved for install....
  3. Mar 31, 2014 at 6:50 PM
    welterbf123
    welterbf123 Well-Known Member
    Columbus, OH
    2017 TRD Off Road
    12voltsolutions.com plug-n-play remote start system. OVTuned OEM Bed lights Underhood and footwell lights Garmin dash-cam Weathertech side vents, bug shield, mud flaps and floor mats Extang Encore tonnau cover OME BP51 Suspension Front & Back / Dakar Leaf Springs Light Racing UCA's XD Holeshot 17" x 9" Wheels Nitto Trail Grapplers 265/70/R17 TRD Pro Grille Raptor Lights iJDMToy 30" LED Hidden Bar Light Toyota Bed Step
    The only problem I see is that it's not very well protected. How about above the bumper step? At least it's a little better protected from the elements...
  4. Mar 31, 2014 at 7:27 PM
    belone12
    Brian
    Long Island, NY
    Thats a good idea. I wasn't sure if it was better off protected from above or below. It claims to be waterproof but i am still going to seal it up. I thought it might be more protected by the trailer hitch.
  5. Mar 31, 2014 at 7:51 PM
    samiam
    samiam Always here, never there
    Sam
    Stinky Vegas
    2008 TRD OR DCSB 4.0 6MT 1E7 Alu Cab
    Workin' on Workin' on it
    I used the 7 pin mounting bracket. It got mangled a while back so I tied it up under the bumper.
  6. Apr 1, 2014 at 5:04 AM
    SGTCap
    SGTCap Well-Known Member
    Cap
    Summerville, SC
    4x4 6-spd,
    37s, 4x4 6-spd, OME 886s, Allpro Expos, SOS sliders and front/rear bumpers,Rack,Skids, 4.56s, Lockers,Recon Winch, TJM RTT, Lots of tools, boxes and gear. Shaggy mutt behind the seat
    Everyone O know that wheels their truck even a tiny bit has mangled the 7 Pin bracket. That looks even less protected. I would drill a hole in the bumper itself.
  7. Apr 9, 2014 at 10:21 AM
    belone12
    Brian
    Long Island, NY
    For anyone interested, I thought it might help since I didn't have much of a reference.
    This is the camera I went with from Amazon - $26 & Waterproof http://www.amazon.com/gp/product/B005Q65JHM/ref=oh_details_o01_s00_i00?ie=UTF8&psc=1
    Hooking it up was relatively easy. I disconnected the battery, removed the HU, and plugged the video cabl in. Then ran it behind the drier side dash -> driverside kick panel, through the rubber grommet under the seat, down the frame to the camera. I tapped into the Power and Ground for the LED bed lights I installed a while back. That is all located behind the Driverside tail light.
    The reverse sensor wire was already connected b/c the PO had an AVIC Z1, so all I had to do was connect to the HU.
    I mounted the camera under the bumper just left of the trailer hitch to offer some protection ( I am not a wheeler). I also siliconed the camera despite it being waterproof.
    I connected the battery, re-installed the HU, and changed the Backup Camera setting to ground. The camera comes on when I shift into reverse or I can manually turn it on at any time (no bypass required, Pioneer HU).
    Overall I am happy with the results for about $30 and a couple of hours of Taco-Time.
    Hope this helps someone else looking for an affordable option. This worked for me, your needs/install may be different so use your judgement...
  8. Apr 9, 2014 at 10:28 AM
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
    Sub'd to show mine
  9. Apr 9, 2014 at 10:31 AM
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    Mounted into the rear bumper. where you put yours I was worried with hitting it backing up, or with trailer hooked to it. Plus less wires hanging down.
    MrPunktoyou likes this.
  10. Apr 9, 2014 at 12:38 PM
    belone12
    Brian
    Long Island, NY
    Thats nice flush mount. The design of the camera I used isn't the best for through fitting, but i may still try it if i can figure out a way to do it.
    I too am concerned about losing it, but i wrapped the wires around the hitch frame so nothing is dangling (except the camera of course)
  11. Apr 9, 2014 at 12:42 PM
    DRP6833
    DRP6833 Well-Known Member
    Dave
    Frederick, CO
    2014 Tacoma I4 4WD
    Newlife, I was thinking about a similar mounting. Does the bumper clip off any of the image on the sides?
  12. Apr 9, 2014 at 12:43 PM
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    Negative sir
  13. Apr 9, 2014 at 2:17 PM
    Suenter
    Suenter Member
    Easton PA
    2013 Access Cab 4x4 SR5
    I have a 2013 SR5 with the camera in the mirror, which is great if your tailgate is up. However as a renovation contractor, I do backup with the tailgate down often.... so while replacing the head unit I installed the wiring for an additional backup camera on the bumper. I chose the licence plate unit sold on Amazon, nice and clear on the head unit.:)
  14. Apr 9, 2014 at 2:36 PM
    tacopromatt
    tacopromatt Matt's Pro Taco (SOLD)
    Austin, TX
    2017 Cement Tacoma TRD Pro AT
  15. Oct 17, 2019 at 11:29 AM
    dirtnsmores
    dirtnsmores A camping truck
    Southern California
    06 DCLB Prerunner
    OME885/5100, DAKAR MED-DUTY, SOFTOPPER
    some good ideas here. would love a few more for my 2006. anyone else?
