Aftermarket ball joints
Discussion in '1st Gen. Tacomas (1995-2004)' started by ijm01PR, Dec 6, 2021.
  1. Dec 6, 2021 at 1:03 PM
    ijm01PR
    ijm01PR [OP] Well-Known Member
    Alex
    Indiana
    01 DC Prerunner (4x4 TBD)
    Ome 881s w/ 5100s and jba ucas 2” pro comp AAL with 5100s in the rear
    Thanks for any advice in advance!
    I called the yota dealership today and they quoted me $600 for oem upper and lower ball joints. Does anyone have a recommendation for any aftermarket ball joints. I have a family member who has an 01 who replaced his with some aftermarket’s and his lower went out on the passenger side wrecking everything including the fender.
    thanks for any advice!!
  2. Dec 6, 2021 at 1:16 PM
    Toyoda213
    Toyoda213 Well-Known Member
    Jimmy
    SoCal
    2003 V6 dlbc Prerunner 4x4 converted
    OEM for the win. Dont cheap out on these specific parts
    TACOTU3 likes this.
  3. Dec 6, 2021 at 1:24 PM
    Majek16
    Majek16 Member
    2003 Tacoma TRD V6 4x4 Manual Transmission
    K&N air filter element
    McGeorge Toyota on-line for OEM. Not that much higher than aftermarket.
  4. Dec 6, 2021 at 1:33 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Was that an INSTALLED price?
    Those usually aren't more than $110 or so each.
    Here:
    https://parts.camelbacktoyota.com/v...4-gas/front-suspension--suspension-components
    A generally acceptable alternative to OEM are the 555 balljoints. The few bucks you save going with some semi generic brand really isn't worth it. I've been served well by the 555's from lowrange offroad (555 is an OEM supplier), but if you were even considering spending $600, just get the oem ones from the above dealer and replace them yourself. It's really not hard at all. Just need a pitman arm puller which are like $15 at harbor freight.
    If you care to read it, I have a little diatribe on my build page (link in my sig) about balljoints, where I go into a little more detail, but suffice to say it's best to get the best you can afford, in this order: OEM, 555, Moog, nothing else.
    tha_roost, ijm01PR[OP] and 0xDEADBEEF like this.
  5. Dec 6, 2021 at 1:38 PM
    YotaGangYotaGang
    YotaGangYotaGang PreRunners are wannabe 4x4’s
    Covina
    95, 97, 01 Tacoma | 06 Tundra | 07 FJ Cruiser | 08 Prius
    A rtt i never use and 30 light bars
    oem online price longo toyota
  6. Dec 6, 2021 at 1:49 PM
    jbrandt
    Justin
    For a normal every day driver? Nah.
    Believe it or not, uniballs require more maintenance than regular balljoints (granted, it's easy), and the propensity for failure of the stock ones is way overblown. The BJs don't just randomly explode for no reason. Either the owner never did the recall, or they never cared to check them for slop and drove for 200k miles on worn out BJs, or installed them wrong (I see a lot of bolt failures, not the actual balljoint).
    Don't get me wrong, I'm highly interested in them. I posted on day one of that thread. But I'm still skeptical. After 1st posting ~2 years ago, the OP went dark for a long time, and only recently posted back up that he's interested in getting production going again. This is most definitely not a solution for the mass market. At least not yet.
    BassAckwards[QUOTED] likes this.
  7. Dec 6, 2021 at 1:50 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    I have been abusing Moog ball joints for a couple years with 35s, I just grease them every couple months. No play yet.
    ijm01PR[OP] likes this.
  8. Dec 6, 2021 at 2:07 PM
    YotaGangYotaGang
    Covina
    OP of youre gonna upgrade with a lift down the line you can get uca instead of upper ball joints, like Total Chaos uca
  9. Dec 6, 2021 at 2:16 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
  10. Dec 6, 2021 at 2:19 PM
    ijm01PR
    Alex
    Indiana
    That’s a good point. Thing is, I wanna go 881s in the front with 5100s, I was under the impression that I would not technically NEED to get aftermarket UCA’S, I was trying to avoid getting them if possible. Maybe need to do some more thread surfing before making a decision.
  11. Dec 6, 2021 at 2:22 PM
    ijm01PR
    Alex
    Indiana
    No this was just for the parts themselves. I originally was planning on doing them when I do the lift but I’m on the fence now. So many options lol!
    Thanks for the info and thread. I’ll go check it out.
    jbrandt[QUOTED] likes this.
  12. Dec 6, 2021 at 2:24 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    You could buy the parts, tools and a floor jack for less than they quoted. Probably take an hour per side at most.
    ijm01PR[QUOTED][OP] likes this.
  13. Dec 6, 2021 at 2:32 PM
    Toyoda213
    Jimmy
    SoCal
    OP where are you located?
  14. Dec 6, 2021 at 3:15 PM
    ijm01PR
    Alex
    Indiana
    I’m in northern Indiana.
  15. Dec 6, 2021 at 3:42 PM
    Nano909
    Nano909 Stirrer Of Pots
    Xcab 3.4 4wd 5MT
    I know a guy that beats prices for OEM Toyota parts.
  16. Dec 6, 2021 at 3:50 PM
    Toyoda213
    Jimmy
    SoCal
    if you were in socal i would help you out changing those ball joints
  17. Dec 6, 2021 at 4:04 PM
    ijm01PR
    Alex
    Indiana
    Shoot man I appreciate that. I’m thinking I’m going to do it all at once when I get the lift components. Only way to learn is to do it. It can’t be that hard.
    unstpible likes this.
  18. Dec 6, 2021 at 4:11 PM
    YotaGangYotaGang
    Covina
    if you lift you need uca
  19. Dec 6, 2021 at 4:21 PM
    Toyoda213
    Jimmy
    SoCal
    im still running my stock uca's on a lift but its only about 3 inches. Im still able to get good numbers on my alignment and i dont plan to go any higher
    Wulf likes this.
  20. Dec 6, 2021 at 4:22 PM
    Wulf
    rock raisin
    Not necessarily, no.
    It depends on the truck and alignment numbers you can get
