Aftermarket black headlights. Which brand is best?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HI SPEED, Sep 24, 2012.
  1. Sep 24, 2012 at 7:24 PM
    HI SPEED
    HI SPEED [OP] Member
    Honolulu
    speedway Prerunner
    I am to lazy to open up my headlights. I am planning on doing a retrofit at some point, but for now I just want to eliminate the hazy stock chrome lights.
    When I began searching I noticed that there are tons of different brands that make black lights. They all seem to be in the $150-$250 range. Is there any one brand that is the best? Don't mind paying on the higher end but only if they are appreciably better.
    Let me know your experiences with brands, and how much you paid.
    Thanks
  2. Sep 24, 2012 at 7:28 PM
    HI SPEED
    Honolulu
    speedway Prerunner
    This is for a 2006 btw
  3. Sep 24, 2012 at 7:35 PM
    ToyotaKTMracing
    ToyotaKTMracing The Blue Warrior
    Shay
    West Virginia
    2008 DCSB Ink 4WD Auto
    285 BFG ATs, Custom dual exhaust system, 4" total lift (adjustable billies with 885 coils in front and AALs with 1" block in rear), interior LED lighting, LED reverse lights, LED license plate lights, fog light anytime mod, JVC KW-R500 stereo, 20" okledlightbars.com LED light bar, coverking seat covers
  4. Sep 24, 2012 at 11:08 PM
    HI SPEED
    Honolulu
    speedway Prerunner
    Do you have these? Any problem with fit/finish and especially fogging up?
  5. Sep 24, 2012 at 11:49 PM
    Casey05Taco
    Casey05Taco Well-Known Member
    Casey
    Penngrove, CA
    05 Tacoma Prerunner
    trd seat covers, bed mat, tinted windows, debadged, mud flaps removed, tinted tails, blacked out center console, Black Rims, 6000k HID in highs and fogs, blacked out front emblem, Pioneer AVH-4300DVD, Gauge Cluster, lower valence, retrofitted, audio system, Maxtrac Spindles, Billies
    Those jdms are good, but your stock headlights are the best you'll probably find until you do the retrofit. If you go with those jdms (or any aftermarket lights for that matter) get some ge silicone and put a bead around it. It'll reduce the chances greatly of the lights fogging on you.
  6. Sep 27, 2012 at 1:43 PM
    HI SPEED
    Honolulu
    speedway Prerunner
    Just squirt liberally around the seals? Does anyone sell a basic pre retrofitted light? No of fence to guys that run them but the angel eye led lights aren't my style.
  7. Sep 27, 2012 at 1:56 PM
    D44boy
    D44boy Well-Known Member
    Kaneohe, hawaii
    2011 prerunner double cab
  8. Sep 27, 2012 at 1:57 PM
    CRU
    CRU Well-Known Member
    Seminole Cnty, FL
    07 SSM TuRD Sport DCLB
    20" Enkei WT4 wrapped in Bridgestone Dueler A/T Revo 3 265/50, Steel braided brake lines, Pioneer AVH-X5500BHS deck w/JBL GTO cones, OEM Smoked headlights, OEM LED tails, Clazzio seat covers, aFe Pro-Dry S air filter, Fumoto oil valve, Grillcraft MX grille w/Land Cruiser "TOYOTA" emblem, Redline QuickLIFT hood struts, Leather TRD shift knob, 13" shorty antenna
    Put a thick bead down on the seal between the lens and the grey backing. Then take some plastic grocery bags, wrap your fingers in them and use them to press the silicon into the seal. Keeps your hands clean. :D
  9. Sep 27, 2012 at 2:02 PM
    D44boy
    Kaneohe, hawaii
    oh yah and FYI i still did the silicone bead anyway
  10. Sep 27, 2012 at 2:41 PM
    Johnsredline
    Johnsredline Well-Known Member
    North Las Vegas
    Barcelona Red- Method Double Standards, Flowmaster Exhaust, K&N intake, black headlights and raptor style grille, ICON stage 4 suspension, allpro sliders
    I have the JDM lights and they both leaked, I ended up opening them and reasealing. It wouldnt be necessary to open them up, but i had to clean the lens from the prior leak.
    Like others said, just run a bead of silicone along the edge, and also in the top corner youll see a small screw, cover that with silicone as well, that was the main leak on my passenger side light.
  11. Sep 29, 2012 at 2:58 PM
    HI SPEED
    Honolulu
    speedway Prerunner
    I was about to pull the trigger on the Revotecs but then I saw the $120 shipping to Hawaii. Ouch.
  12. Sep 30, 2012 at 9:48 AM
    mytac
    mytac Well-Known Member
    T
    FV
    05 4X4 TRD
    TRD Intake, 2011 front grille
    2 this, they sell pretty good stuff, I'm happy with mine as well.
  13. Sep 30, 2012 at 10:00 AM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    There are members on here who will do a TRS retrofit the way you want and mail it to you. It will cost more but if you're too lazy to do it right yourself then you have to be rich enough to have someone else do it right for you.
    Your stock headlights are better than most of those weak ebay ones. To save hundreds i'd say just bake em yourself
  14. Oct 1, 2012 at 8:08 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    One other note, I ran a set of the aftermarket BHLMs for awhile. While the lights worked fine and I didn't have any leakage problem, I did notice that the light distribution pattern was not as good as stock. The aftermarket's light had a hot-spot in the center of the pattern, and then was dimmer around the edges. Not dangerously so, but enough that I ended up going back to a stock HL (the smoked TRD version though).
    BTW, I bought from my aftermarkets from Revotek.
  15. Oct 1, 2012 at 2:38 PM
    T1no33
    T1no33 Well-Known Member
    Spring Hill, Fl
    2012 PreRunner V6 SR5
    - Partial Badge Removal & Dipped - Removed Mud Flaps - Blacked out Emblem - Blacked out Chrome Surrounding Grill - Salex Center Console Organizer - AntennaX 13" - Tinted Front Windshield - Derped Tacoma Emblems - Bridgestone 265/70/16 tires - Tuff AT Wheels - 3 and 1 spacer block lift (mistake big time) - Black Rear Bumper - Aries Bull Bar w/light rig
    Has anyone on this thread done the BLHM? How hard is it to do? I want to do it just scared to back my headlights.
    Signed Chicken Shiz.....
  16. Oct 1, 2012 at 2:45 PM
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    There are many write ups on here man, just search BHLM write up and read through a few of them and look at pictures until you feel comfortable
  17. Oct 1, 2012 at 7:44 PM
    hakabo
    hakabo Well-Known Member
    Jacob
    Concord, NC
    08 urban runner 4x4
    The mod was easy. Just took half a day and a can of paint. I was scared at first but once I got the light open it was smooth sailing. Word of advice though, if u do it have some wax paper handy when u are putting the reflectors back in as they tend to scratch some of the paint. Also, tape over the turn signal, dtrl reflector. It'll be covered by separate pieces of plastic. I painted mine and now it is difficult to see my turn signal during the day.
  18. Jan 10, 2020 at 2:19 AM
    jtaco
    jtaco Well-Known Member
    07,trdOR,DC,4x4,v6,saw2.5s,OMEdakars,LRarms
    saw2.5s,AEMshortair,skyjackershocks,LRa-arms,OME dakars,Alpine,JL audio 6x9 3 way in front doors
    wheres the smoked TRD version for 07 tacomas ?
  19. Jan 10, 2020 at 3:38 AM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    It’s so easy! First time I did a set I was 15...been doing it ever since lol!
  20. Jan 10, 2020 at 6:36 AM
    kfs90
    kfs90 Well-Known Member
    BR, LA
    2013 Prerunner V6
    There is a better silicone for this that is more of a liquid and runs into the cracks of the seal. Get it at any auto parts store. Two tubes can do once around each headlight then touchup about half of each if needed after drying. This is much easier than the normal thick silicone. I never smelled it gassing off either.
