Aftermarket Blower Motor
Discussion in '1st Gen. Tacomas (1995-2004)' started by inf811, Feb 6, 2023.
  1. Feb 6, 2023 at 10:08 AM
    inf811
    inf811 [OP] Well-Known Member
    Any recommendations on an aftermarket blower motor?
    The one I purchased from CarParts.com did not fit since the fan was too big to spin once inside of the housing.
  2. Feb 6, 2023 at 10:10 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Honestly I would buy a used Toyota one from someone on here. I have the Four Seasons one from AutoZone in my truck and I hate how weirdly loud it is. Sure it's $60, but it's also kinda a POS. @Tour991 do you have a blower motor for our friend here?
    inf811[QUOTED][OP] and Tour991 like this.
  3. Feb 6, 2023 at 12:08 PM
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    I do have one out of the 99. I still need to power the truck up to see how it works.
    inf811[OP] likes this.
  4. Feb 6, 2023 at 12:13 PM
    inf811
    If you do have one that works and doesn't sound like it's on its way out that would be awesome. Mine still functions but has gotten noisy as of late.
  5. Feb 6, 2023 at 12:16 PM
    Tour991
    James
    South Reno/Tahoe
    Ill try and get it spinning Thursday and let you know how it is.
    inf811[QUOTED][OP] likes this.
  6. Feb 6, 2023 at 12:17 PM
    inf811
    Awesome, thanks.
    Tour991[QUOTED] likes this.
  7. Feb 6, 2023 at 12:21 PM
    Nessal
    Nessal Well-Known Member
    Texas/Bay Area
    2003 V6 4X4 TRD DCAB
    I replaced mine with a TYC two year ago. It was louder than OEM initiately but has quieted down considerably.
  8. Feb 6, 2023 at 12:22 PM
    99TacoDriver
    99TacoDriver Well-Known Member
    South Louisiana
    OME 885x/5100s/LR UCA/3 leaf AAL/275/70/17 Terra Trac X-Venture
    have you cleaned it? those motors get dirt/leaves/bugs in there. you can clean it and put some white lithium grease
    i'd imagine the process for first gen is similar to 2nd gen
    https://www.tacomaworld.com/threads/blower-motor-squeek-chirp-on-low-fix.28355/
  9. Feb 7, 2023 at 5:15 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Just what is wrong with yours?
    Is it the squirrel cage or the motor?
    The plastic gets brittle with age.
    My motor was starting to make noise about 10 years ago I pulled it out took it apart cleaned and lubed going strong 10 years later.
    I would buy Tour991 blower motor if it works may as well install a new resistor as well. Good for another 10 years.
  10. Feb 7, 2023 at 10:11 AM
    inf811
    I am guessing the cage, it spins fine but is just noisy. I've only owned the truck about 3-4 weeks so I am not sure how it sounded before.
  11. Feb 7, 2023 at 11:40 AM
    Cucvfan
    Cucvfan Well-Known Member
    I got 1 from Napa and the plug did not match the factory wiring harness.
    I ended up buying a blower motor from the dealer.
    It was a few years ago. I think I paid $130 for it. Hopefully it last another 20 years.
  12. Feb 7, 2023 at 11:47 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    I'd actually really like to know what you did you lube it. I've pulled mine before to clean it, but I couldn't figure out to get the cage off. Whatever I did made it sound worse, and I have just delt with it. But older and wiser me would like to continue to correct the things I messed up as a teenager.
  13. Feb 7, 2023 at 12:00 PM
    Bivouac
    It has been 10 years or so I can`t recall having trouble removing the cage .
    I did what needed done I would need to look at the motor again
    It took the motor apart and even though the bearings are sealed I am pretty sure I got some Kroil with silicone in them.
    Sprayed the squirrel cage with silicone spray after blowing all the interesting collection of dirt out of the enclosure
    Put a new resistor in so far so good.
    I think I have a new motor not sure just which one it is I have a few.
  14. Feb 7, 2023 at 12:03 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    See post #51 in my build thread. I pulled it out, removed the bottom access panel and hit it with some WD-40 and it sounds so much better and pretty easy to do. Been going strong for about 10 months now. If I were to do it again I'd likely use WD-40 silicon spray, but I just used what I had on hand.
    Andy01DblCabTacoma likes this.
  15. Feb 7, 2023 at 12:07 PM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    Gotcha. I tried to remove the cage. It had a c clip or something like that on it. Didn't want to come off easily. I put it back together and it was never the same.. I guess I'll give this a try this weekend.
  16. Feb 7, 2023 at 12:11 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Yep, I attempted the same and couldn't get it off without likely damaging it either. I found accessing it from the back as shown in the post worked well enough though. If you've bent the shaft or have play in the bearings oiling it won't help and it will need to be replaced. I'd certainly go OEM if so, a little more expensive but better than getting an aftermarket one that doesn't work properly or is annoyingly loud and then having to buy OEM anyway.
  17. Feb 7, 2023 at 8:08 PM
    1997tacomav6
    Denver
    I just replace my fan with an OEM fan and OEM resistor and OEM blower switch.
    The fan switch was going out and the switch terminals were burning up actually melting the plastic switch possibly from the fan going bad.
    Fan bearing was humming loudly so I replaced everything.
    now it’s all back together and normal with all OEM parts and no funny fan noises,
    This is the 2nd time in 20 years I've
    replaced these 3 parts all at the same time and both the motor and switch were going bad at the same time.
  18. Mar 11, 2023 at 7:04 PM
    herrindude
    herrindude 1996 2.4 extra cab auto
    Fairhope al
    2021 dclb sr5
    ARE camper shell
    The motor has a place to squirt some oil to lube bearings, works for me
