Aftermarket bumper on a stock truck?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by angdefeo, Jul 26, 2012.
  1. Jul 26, 2012 at 8:14 AM
    angdefeo
    angdefeo [OP] Well-Known Member
    I am new to the world of Taco’s and cannot figure out a few things about front after-market bumpers. Most of the photo’s that I see with trucks running aftermarket bumpers also have lifted and upgraded suspensions. Is a lift and upgraded shocks and springs needed in order to allow for an aftermarket bumper from any of the various brands? Or can they mounted on a stock truck? I assume the extra weight could have an impact on the stock components.
  2. Jul 26, 2012 at 8:17 AM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    THe bumpers can be mounted on a stock suspended truck. As you stated, the extra weight would cause the front suspension to droop slightly, most add heavier springs to compensate.
  3. Jul 26, 2012 at 8:18 AM
    Enzo
    Enzo Well-Known Member
    Opie
    Bedford, Va
    2012 FJ Cruiser
    2012 FJ Cruiser Maggiolina Medium Grand Tour w/winter hood National Luna dual battery split charging system ABR Sidewinder Aux battery tray ARB 50qt Fridge w/Transit Bag Bajarack flat rack w/ladder Crawlarado flat black hood blackout TRD exhaust Trasharoo Outback FJ roof console
    With an ARB bumper you will need something up front to support the extra weight. Not sure on other bumpers though. I will say that ARB is the only bumper that looks good on a stock truck. The others are just to bro.
  4. Jul 26, 2012 at 8:20 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    I bought my truck with an ARB bumper and Stock Suspension. It will handle it just fine. The ride is not what I wanted it to be and the front suspension was bottoming out on harsh dips/bumps.
    If you don't mind that you can stay stock, but honestly if you can stiffen up/lift you will be doing yourself a favor. Check my build thread for pics of the stock suspension.
  5. Jul 26, 2012 at 8:22 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Relentless Fab makes an aluminum plate bumper that only weights like 60 lbs. Aluminess also makes aluminum plate bumpers but I don't know what they weigh. They'd be easier on your front suspension than plate steel.
    jdmcq is correct though, you can put a plate bumper on a stock sprung Tacoma but it'll sag depending on which bumper you choose. Personally, I wouldn't put an ARB on a stock Tacoma, those suckers are pretty damn heavy!
  6. Jul 26, 2012 at 8:26 AM
    angdefeo
    Thank you for the advice!
  7. Jul 26, 2012 at 8:31 AM
    JDMcQ
    Plate is not the only option. Tube bumpers or one of the hybrids work well too and weigh a little bit less.
  8. Jul 26, 2012 at 8:36 AM
    Pugga
    Massachusetts
    Good point, but who runs a tube bumper in the northeast... :rolleyes:
  9. Jul 26, 2012 at 8:38 AM
    JDMcQ
    True, only weirdos and posers.
  10. Jul 26, 2012 at 9:13 AM
    angdefeo
    I am all about posing.....:crazy:
  11. Jul 26, 2012 at 9:18 AM
    angdefeo
    One more question for you all. What is the effect of adding bilstien shocks (since it seems to be one of the first mods that is made to suspension) to the ride on city/highway roads?
  12. Jul 26, 2012 at 9:23 AM
    angdefeo
    Jdmcq....are you in Kennet Square, PA?
  13. Jul 26, 2012 at 9:23 AM
    JDMcQ
    He said that because I am in the NorthEast (Kennett Square) and have a tube bumper.
  14. Jul 26, 2012 at 9:24 AM
    JDMcQ
    Yes I am! Where in or about Philly are you?
  15. Jul 26, 2012 at 9:33 AM
    angdefeo
    I live in South Phila but spend a lot time at my friends detail shop in West Chester. Actually i am going to Southern Chester County Sportsman and Farmer club on tueday and spend some time on the range.
  16. Jul 26, 2012 at 9:34 AM
    JDMcQ
    Chester County Sprtsmans club is right around the corner.
  17. Jul 26, 2012 at 10:03 AM
    Pugga
    Massachusetts
    Bilstein is a brand but I'm assuming you are asking about the 5100's in particular. The 5100's are valved different (better in my opinion) than the stock shocks and provide for a more controlled ride. They seem to soak up hits much much better than stock. The reason they are so popular, aside from being a decent shock for the money, is they have an adjustable coil seat meaning you adjust the ride height by preloading the coil. This means you can preload your stock coils to gain lift and the 5100's actually do a good job dampening the stiffer coil.
    Sorry, couldn't resist :eek:
  18. Jul 26, 2012 at 10:05 AM
    JDMcQ
    It's all good! Tube bumpers are fruity anyway!
