Aftermarket Camera Question
Discussion in 'Audio & Video' started by MadeInMaine, Oct 12, 2010.
  1. Oct 12, 2010 at 11:43 PM
    MadeInMaine
    MadeInMaine [OP] MadeInMaine
    Owen
    Biloxi, MS
    2014 4Runner
    Hey Guys
    I installed a rear view camera, turns on when I put the truck into reverse, and shows up on my double din headunit.
    I while ago, my battery died, and it was fully dead. Once I charged it up again, I noticed that the camera was now viewing only in B&W and also upside down.
    Does anyone know what this might be? I have never incountered this issue before.
    Cheers
  2. Oct 13, 2010 at 11:41 AM
    MadeInMaine
    Owen
    Biloxi, MS
    2014 4Runner
  3. Oct 15, 2010 at 8:00 AM
    Raylo
    Raylo Well-Known Member
    MD, USA
    2009 4x4 Access Cab, TRD Sport
    Only things I can think of:
    1. Look in your head unit menus for settings such as these and try to change them back.
    2. Disconnect the battery from the truck for awhile. The head unit has unswitched memory power so disconnecting the battery will take that away and possibly get things to reboot when you reconnect it.
    Good luck!
  4. Oct 28, 2010 at 11:26 AM
    MadeInMaine
    Owen
    Biloxi, MS
    2014 4Runner
    Any other thoughts?
  5. Oct 28, 2010 at 2:55 PM
    tacomaintraining
    tacomaintraining Well-Known Member
    i want to install a cam on my pioneer 4200 but I dont know where/how to get the wire back there???????????
  6. Oct 28, 2010 at 8:49 PM
    MadeInMaine
    Owen
    Biloxi, MS
    2014 4Runner
    I ran mine along the inside of the frame, zip tied them up nice and tight
  7. Oct 29, 2010 at 5:13 AM
    polox40
    polox40 Well-Known Member
    ONTARIO
    TRD SPORT 4X4
    TOYOTA ALUMINUM STEP BAR, 3M HOOD FILM, WEATHERTECH FLOOR MATS, 7" DD WITH BACKUP CAMERA, TRD SEAT COVERS
    Get some wire loom to protect the cable under the truck, under the drivers seat their is a big grommet to go through you can run the wire twords the door under the carpet then under the plactic molding thats under the door to the dash, also if there is a splice in your cable twords the camera end , I installed the splice behind the rear brake light, it's nice and dry up there.
