Aftermarket CAT in CA
Discussion in '2nd Gen. Tacomas (2005-2015)' started by basurf9, Apr 22, 2015.
  1. Apr 22, 2015 at 9:00 PM
    basurf9
    basurf9 [OP] Well-Known Member
    Tacoma TRD Off Road
    Hey All,
    So I have two bad CATs, confirmed by dealer. If I get my hands on some CA illegal (49 state) CATs will the smog shop know? I've heard some smog shops look and some don't.
    Thanks
  2. Apr 22, 2015 at 9:06 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    50 state / CA legal cats will have the proper stamp on the cat themselves.
    if a smog shop wants to stay in business with recent crack downs that have been done over the past year or so, they do their shit by the book.
    pony up for the OEM cats unfortunately.
  3. Apr 22, 2015 at 10:06 PM
    locster
    locster Well-Known Member
    Luke
    Orange County, CA
    2014 DCSB 4x4
    How many miles on your truck? CATs are guarranteed for 80k miles, no?
  4. Apr 23, 2015 at 12:37 AM
    Gabezz
    Gabezz Well-Known Member
    Gabe
    Los Angeles, CA (Montebello)
    '12 Tacoma TRD Off-Road DCSB
    Volant CAI w/Ram Air Scoop, Volant Throttle Body Spacer, Flowmaster SS Dual Exhaust, JBA Cat4ward Headers, Body Armor Side Steps, ProComp 3in Suspension w/Pro Runner UCA's and shocks, Various KC Hilites LEDs.
    Barring any major mechanical issues, your truck should pass the functional inspection of the smog check. It's just a machine that will be connected to your OBDII port to read any error codes, the second portion of the smog check is the issue, it will fail the visual portion of the check. The smog technician will specifically inspect the Catalytic converter among other parts. It will be up to him if he passes or fails it with non CARB installed parts (California Air Recources Board), so unless it's CARB certified it will likely fail. You will have to find a smog shop that will look the other way, and pass the visual inspection or maintain OEM CATS. God Bless the Golden state.
  5. Apr 23, 2015 at 7:22 AM
    basurf9
    Tacoma TRD Off Road
    94,000... I called toyota but we all know how that goes.
  6. Apr 23, 2015 at 7:45 AM
    DirtJumper14
    DirtJumper14 Well-Known Member
    SoCal
    2005 TRD OR
    5100's, BDF grills and light bracket, big 3 upgrade, ATH bed braces, snugtop xtra vision shell, (bed, shell, hood, rock, front, rear, footwell, glove box, center console led lighting), MESO Gasshole, MESO dome and map lights, Flyeyez center console light, custom fuse panel, TRD CAI, toyota bed mat, 2013 black carpet, 2015 side mirrors, BedRug, AJT key fob, ultraguage, 8 cadillac horns acdf, pop n lock tailgate lock, energy suspension bushings, spicer greasable ujoints, Rigid lights everywhere, kenwood stereo, led tube taillights (red), 2018 T4R trail wheels, rokblok mud flaps, TRD skid plate, RCi gas tank skid plate
    In twenty years of having to smog my vehicles I have never seen a smog tech look under a vehicle in California. They may look around the engine bay briefly but nothing more. But like you said they plug into the OBDII and in just a few minutes of idling it's done.
  7. Apr 23, 2015 at 8:21 AM
    Vang Toua Moua
    Vang Toua Moua Well-Known Member
    Vang Bang
    Visalia, CA
    05 Silver Tacoma 2.7, Access cab, 5 lug
    Custom front bumper and rock sliders, glasspack muffler, shorten exhuast, abs killswitch, roof light bar, rear e locker.
    urd, they o2 simulators. you can fit in the puzzles of what i had in mind about what i want to do with my cats and the o2 simulators.
  8. Apr 23, 2015 at 9:45 AM
    Gabezz
    Gabe
    They may not bother to look underneath a Camry, Prius or a minivan as are common in city vehicles, but CAT inspection is part of the visual inspection. If you haven't replace your CATS/CAI with non Carb compliant parts in the past 20yrs then you need not be concerned with not passing. My point is as mentioned it will all depend on where you go, if the tech feels like or not doing his job properly, you should know this.
  9. Apr 23, 2015 at 9:52 AM
    keith88lx
    keith88lx Well-Known Member
    Mount Prospect
    15 DCSB TRD Sport 4x4
    I used to live in San Diego and had to get my Mustang Foxbody smogged as usual. I never failed due to cats (however; I did have the correctly stamped Magnaflow cats at the time). I was questioned once for my MSD cap and was told that they couldn't perform the test because they couldn't read the timing on my balancer. Other than that, I've never had a hard time with smog tests.
