Aftermarket clutch or OEM clutch
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Toyotagang, Apr 9, 2021.
  1. Apr 9, 2021 at 1:22 AM
    Toyotagang
    Toyotagang [OP] Well-Known Member
    Kainoa
    2005 black Toyota Tacoma 4cyl 4x4
    my clutch needs replacing, super hard to push down a ton of play and hard to get into gears, as well as starting it up is pain trying to get it into the 'sweet' spot. Should i invest in OEM or Aftermaket clutch? im replacing Clutch and refinishing my flywheel if possible, replacing throwout bearing and pilot bearing am i missing anything ?
  2. Apr 9, 2021 at 5:08 AM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    When clutches go bad they typically slip... Sounds like your issue is with the master or slave cylinder for the clutch.
  3. Apr 9, 2021 at 10:37 PM
    Toyotagang
    Kainoa
    Shoots I’ll look into that more then hopefully that’s the problem ... thanks guy!
    Athlaos likes this.
