Aftermarket coils necessary with 5100s?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JJThomas, May 5, 2020.
  1. May 5, 2020 at 7:41 PM
    JJThomas
    JJThomas [OP] Member
    2019 Toyota Tacoma TRD Sport
    That looks good. Are you running 265’s
    Tacodust404 likes this.
  2. May 5, 2020 at 7:55 PM
    nathanroyse
    nathanroyse Well-Known Member
    Nate
    2019 Tacoma TRD-Offroad 4x4
    Bilstein 5100 w/ OME 887 Springs Bilstein 5160s TRD Pro Grille Method NVs w/ Falken Wildpeaks 265/75/16
    I’m confused, if it doesn’t preload the spring then how do you get lift?o_O
  3. May 5, 2020 at 8:05 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Magic bro.
    nathanroyse likes this.
  4. May 5, 2020 at 8:54 PM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    There are a lot of claims for the 5100 shocks.
    People say when you increase the perch setting you are "preloading" the springs. I don't know if the term preload is just thrown around, but regardless it is the wrong term when it is usually used.
    When you adjust the perch setting on the shock, you are not changing the spring rate or the total force applied, so the spring will always compress the same amount -- moving the perch only changes the position of the spring seat (making the truck taller or lower), not the "preload" on the spring.
    71tattooguy likes this.
  5. May 5, 2020 at 9:51 PM
    shane100700
    shane100700 Bed, Bath & Beyond Crawler
    Montana
    2019 DCSB, OR
    Rocket Boosters
    Here you go... had it saved.
    71tattooguy[QUOTED] likes this.
  6. May 5, 2020 at 10:01 PM
    DevilTaco4
    DevilTaco4 Well-Known Member
    Folsom, CA
    2017 SR Access 5MT
    You can always tell who just mall crawls and who actually off-roads over these debates.
    5100s + stock coils + upper notches = preloading the shock = limiting downtravel (potentially damaging the shock as it over extends).
    cool, if you’re just doing it for looks and stay on pavement where you’ll never notice it. Not cool if you want to retain performance off-road after a lift.
    to each his own, not talking shit - simply the facts. You get what you pay for.
    VaToy likes this.
  7. May 5, 2020 at 10:13 PM
    Estephe21
    Estephe21 Well-Known Member
    Stephen
    Seattle, WA
    2008 DCLB, 2023 DCLB
    Sadly, not much.
    I have the 5100 with stock springs at highest setting. It was a budget choice, and I really appreciate it. My stock shocks were leaking, and it is a HUGE upgrade from that. Ignorance is bliss in some cases, and you got to know what you ride. I do 90% city, 9% Fire service and 1% sketchy. I will not over extend them, and won't need them to perform beyond what they are completely capable of.
    If you want to wheel, baja, or blast FS roads, and not feel it, you really should get another set up. If you want a budget lift, plus an upgrade from stock, you may find this works.
    With that said, my next setup will be OME + Coils + Nitros because I would like to keep the lift + have the ability to add a bumper.
    71tattooguy, VaToy and shane100700 like this.
  8. May 5, 2020 at 11:58 PM
    nathanroyse
    Nate
    When you put the spring on a higher perch, the perch and top hat are closer together, therefore compressing the spring... aka preloading the spring.
    Preload
    is a measurement of how much a spring is compressed at full extension of the shock.
  9. May 6, 2020 at 2:01 AM
    VaToy
    Parts Unknown
    Okay, thanks.
  10. May 6, 2020 at 4:16 AM
    Tacodust404
    Tacodust404 Well-Known Member
    Florida
    2016 Limited - Quicksand
    Yes
  11. May 6, 2020 at 4:18 AM
    Tacodust404
    Florida
    Yes!!! This is correct! I don’t know why everyone else is talking about the spring being compressed more. That’s incorrect.
    71tattooguy and VaToy[QUOTED] like this.
