Aftermarket "combination meter"
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ThunderStruck14, Sep 12, 2022.
  1. Sep 12, 2022 at 5:34 PM
    ThunderStruck14
    ThunderStruck14 [OP] Member
    Northern Nevada
    2019 TRD off-road
    Toytect 2.0 alum coilovers and rear shocks. SPC uca.
    Hello,
    My Tacoma was struck by lightning 2 months ago and it fried a few computers including the "combination meter". The part number is 8380004F60RP. The dealership originally told me that they would have one tomorrow (after a couple weeks of waiting). Now they say it will be another month and a half. I can't wait that long. Does anyone know if this is something I can just replace with an aftermarket gauge cluster and everything will be fine? Thanks
  2. Sep 12, 2022 at 6:10 PM
    ThunderStruck14
    Northern Nevada
    2019 TRD off-road
    Or another stock cluster off ebay?
    reallifedog and Key-Rei like this.
  3. Sep 12, 2022 at 6:15 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Did you contact your insurance in regards to the strike? Most will cover it and put you in a rental until it's fixed.
  4. Sep 12, 2022 at 6:17 PM
    ThunderStruck14
    Northern Nevada
    2019 TRD off-road
    I did. Its covered but they didn't say anything about a rental car. I will call tomorrow and check.
  5. Sep 12, 2022 at 6:20 PM
    Key-Rei
    Key
    Florida
    Otherwise yeah ebay used cluster is about your only bet.
    To fit an aftermarket would take significantly more cost and modifications to your factory wiring if it would work at all.
    Alternatively, while not the best option, you could get the Torque app for Android and use an OBDII dongle to get your speed and RPMs and such if the truck starts and drives otherwise.
  6. Sep 12, 2022 at 6:29 PM
    Bishop84
    Bishop84 Well-Known Member
    We had a tacoma f'd up badly from a lightning strike.
    You could see the arch from the wheel even.
    Messed up every computer and melted most harnesses. Brutal.
  7. Sep 12, 2022 at 6:32 PM
    ThunderStruck14
    Northern Nevada
    2019 TRD off-road
    The guy in the parts department was giving me a hard time because the mileage would be off with a new cluster unless they set it or something like that. Maybe I can ebay one and ship it to the dealership. Yea this has been a nightmare and im looking at not having a truck for 4+ months..
  8. Sep 12, 2022 at 6:32 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
  9. Sep 12, 2022 at 6:37 PM
    ThunderStruck14
    Northern Nevada
    2019 TRD off-road
    Yea mines at about 86,000. I just don't know what the legality of just putting in a new cluster is. I asked the parts dept if I could buy one off ebay, well see what they say. If they can change the mileage or whatnot, I'll definitely be buying that one.
  10. Sep 12, 2022 at 6:40 PM
    Key-Rei
    Key
    Florida
    You just have to declare it on your title that the milage does not match the odometer if you ever sell it and transfer the title, you might have to declare it to your insurance depending on state.
    ODO not matching actual milage isn't as big a deal as the kid behind the counter thinks it is and or is making it out to be it's actually a very common thing.
    It's only a big issue if you knowingly and intentionally use falsified information to deceive a buying party into paying more.
    Otherwise it's not much more than a way of estimating when to change your oil, when you're low on gas if your gas gauge is broken or knowing how far you went.
    It's not nuclear launch codes lile the parts guy seems to be protecting it like.
    Try a different dealer.
    Also AFAIK there's not a way to "program" the milage either.
    Ricardo13x and Dm93 like this.
  11. Sep 12, 2022 at 6:41 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    AFAIK it's legal as long as it's disclosed on the title when the vehicle is sold.
    I'm not sure if mileage can be altered on a used cluster or not or if it can only be written to a new one.
    Ricardo13x likes this.
  12. Sep 12, 2022 at 6:43 PM
    ThunderStruck14
    Northern Nevada
    2019 TRD off-road
    Hmm that is helpful. Thanks guys.
  13. Sep 13, 2022 at 4:01 AM
    Brandon###
    Brandon### Well-Known Member
    I’ve swapped clusters on a GM truck before. I was able to give my current mileage to the guy and he programmed the new cluster with it.
    There are YouTube videos showing how to do it on various models. Some show it involving de-soldering an e-prom and connecting to a computer for programming.
    **Just checked eBay and there are sellers offering repair services for clusters and reprogramming.
    I would try to see if they can repair it, if not you’re not losing anything. You can always buy a used one and have it reprogrammed for replacement.
    SR-71A likes this.
  14. Sep 13, 2022 at 9:05 AM
    Tactical_Panda
    Tactical_Panda Armchair Anarchist
    Tim
    Fredericksburg, VA
    2015 Tacoma Double Cab, Off-Road Edition
    AJT Designs Shifter AJT Designs Battery Hold-Down ARB Awning 2500x2500 ARB Twin Compressor w/ Slee Offroad Mounting Bracket Avid Brush Bar Avid Step Bars Black Rock Wheels Series 997 Type 8 Circuit Breaker/Relay Panel Custom TRD Decals Bulletproof Fabricating Raptor Grill Bulletproof Fabricating Cooling Panel Bulletproof Fabricating Tow Hook Duluth Trading Company Dog Hammock Exhaust Breather Mod eBay Special 3-Gallon Air Tank Expedition Essentials TPAM EZ Down tailgate damper Flagpole Mounts, Dual Foglight Mod Front Camera Rear Camera; full time available General Grabber tires Goat Armor Hella Supertone Horns Iggy Switch Panel Icon Dynamics Stage 3 Suspension Katskin Leather Interior KickAss camp shower LED Bed Lights LED Interior Lights Midland MXT275 GMRS Two-Way Radio OEM Audio Plus Reference 500 audio upgrade Plano Cases. 42" roof mounted, X2 Pop-N-Lock Tailgate Handle Prinsu Cab Rack Prinsu-like Shell Rack Redline Tuning Hood Struts Rigid Industries 40" Light Bar Rigid Industries Ditch Lights Rigid Industries Spotlights Toyota Bed Step UltraGauge EM Plus v1.4 Vixen Air Horns, Four-Trumpet Whole bunch of decals worth about 5HP each Yakima Road Shower, 10-gal
    Usually, you have to pay extra on your premiums if you want rental car reimbursement.
    SR-71A likes this.
  15. Sep 13, 2022 at 9:11 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Seem to recall a conversation on here a while back about moving the eprom from one cluster to another.. Suppose that requires the old one to still be functional though, if its even possible
  16. Sep 13, 2022 at 9:49 AM
    Leomania
    Leomania Well-Known Member
    Leo
    2011 Tacoma TRD Sport DCLB v6 4x4
    All stock, baby!
    @ThunderStruck14, see this post, the author indicated he was able to have the mileage programmed when he bought his refurbished cluster.
    ThunderStruck14[OP] likes this.
  17. Sep 28, 2022 at 8:03 AM
    FishyTaco1976
    FishyTaco1976 Active Member
    2005 DS Mica Tacoma V6 TRD
    ARB 2.5" OME Lift, 17" Method Racing Wheels, 285 75R/16 BGF TA KM3 Tires, ARB Roof Rack, ARB 2000 Awning, ARB Front Bumper, Smittybuilt XC Winch
    This thread could not come at a better time.
    Yesterday I had my truck looked at due to a p0500- speed sensor "a" code.
    Brief backstory-- Check engine light came on, scanned, saw code p0500, cleared it using scan tool, code came back, I replaced front axle speed sensors, code came back.
    My mechanic ran the through his machine. He said that the instrument cluster will most likely need to be replaced "when it gets worse". Meaning that the instrument cluster is going bad and the speed sensor "a" is the cluster. He gave me the same line about needed to get the milage burned to a new unit if I ever want to sell the truck (yeah right). I called the local Toyota parts guy and he said he's seen it take a week for them to send out the old unit and have the milage burned into the new one. I think these guys are coving their asses and are afraid or unwilling to admit that differing milage on an ODO is not as big a deal as they think. We aren't dealing in state secrets here.
  18. Sep 28, 2022 at 5:15 PM
    Soulsurvives
    Soulsurvives Well-Known Member
    Bill
    2009 Tacoma
    Some states like New York stop requiring mileage on a title after ten years.
  19. Sep 28, 2022 at 5:33 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    As long as the mileage is marked not actual on the title and the vehicle is not sold as having less miles than it actually has your fine.
    The shops are just covering themselves because if the vehicle ever turns up somewhere having been sold as a lower mileage vehicle than actual it could come back to them if records show conflicting odometer readings.
    FishyTaco1976[QUOTED] likes this.
