Aftermarket CV Axles?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SLC TACOMA, Aug 9, 2011.
  1. Aug 9, 2011 at 7:00 AM
    SLC TACOMA
    SLC TACOMA [OP] Member
    Tim
    SLC, UT
    08 4x4 DC, LB TRD SPORT
    5100's, 1.5 Block, LEER TOPPER, Winter=Blizzack on Stockers Summer=TBD
    Biting the bullet and having my stealership replace the needle bearing in my front differential due to the famous 2wd vibration after 2.5 inch lift via 5100's. My question is: Do I go with the Toyota factory CV axle @ $447 or the autoparts store CV. Napa is $110 and O'reilly is $70, both having lifetime warranties. Toyota part has a one year warranty vs the lifetime on aftermarket parts.... Stealership doesn't care if I bring in the aftermarket part so I think I'm going that route but wanted to get some opinions from the collective.
  2. Aug 9, 2011 at 7:06 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    I go after market on mine I would rather spend 70 bucks once then 447 every time I rip a CV boot.
  3. Aug 9, 2011 at 7:07 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    go after market!
