Aftermarket disc brakes
Discussion in '1st Gen. Tacomas (1995-2004)' started by Soflanick, Jul 23, 2015.
  1. Jul 23, 2015 at 7:36 AM
    Soflanick
    Soflanick [OP] Well-Known Member
    Nick
    FLORIDA
    2001 tacoma prerunner
    5100 front, 5125 rear, 2"all, old ARE topper, 16x8 XD enduro's on 265/75r16 KO2's
    Anyone have issues with aftermarket brake discs?
    The Prev owner told me he tried aftermarket ones and they warped on him, although the what I assume oem discs are warped also.
    Looking on Amazon, looks like I can do a full brake job for $100 ....
  2. Jul 23, 2015 at 10:29 AM
    Holy schmidt
    Holy schmidt Well-Known Member
    Wyatt
    Nebraska
    I have had aftermarket ones on my truck for 30k now and no warping. Now the brand they are might make a difference
  3. Jul 23, 2015 at 10:37 AM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    Brake discs don't just warp for no reason. There are specific causes that attribute to warping or "excessive runout". Overtorqued/undertorqued lug nuts, inproperly installed brakepads, inproperly beded brakes, ect. If you follow the manufactures recommendation to break in, and torque everything correctly, you shouldn't have an issue. Also remember to clean your mounting surface on the hub, and if there is excessive corrosion, they need to be replaced, or check runout, and shimmed. Remember brakes don't warp typically (unless extreme heat is applied), instead the develop lows and highs on the braking surface causing the vibrating and poor breaking performance.
  4. Jul 24, 2015 at 8:24 AM
    joshhemming
    joshhemming Active Member
    Josh
    El Paso
    03 Tacoma SR5 2.4L Extended Cab
    I installed Autozone Duralast pads and rotors on my 2003 Tacoma 2.4L at 55,000 miles. It now has 75,000 and no problems.
  5. Jul 25, 2015 at 8:52 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I think people who just install pads without doing the rotors run into issues more often
    My last Front brakes were Toyota Rotors and pads a few years ago.
