Aftermarket driveshaft
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Owenhall, Jan 16, 2025.
  1. Jan 16, 2025 at 9:11 PM
    Owenhall
    Owenhall [OP] Well-Known Member
    Owen
    2009 Toyota Tacoma 4x4
    Lift 33s
    My driveshaft on my truck is a little worse for wear, I have replaced u joints and carrier bearing. But my slip yoke clunks and is sloppy I grease it and it temporarily stops clunking.I am wondering if anyone sells a decent aftermarket or custom driveshaft.
  2. Jan 17, 2025 at 7:06 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    For driveshafts, I go to my local driveline shop and have them make them or repair. Fleet Pride is my local go to. They are nationwide.
  3. Jan 17, 2025 at 7:37 AM
    Owenhall
    Owen
    Lift 33s
    How much do they charge?
  4. Jan 17, 2025 at 7:40 AM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    A lot less than buying a new OEM. It’s been a while but the last one I had made for a classic car was in the $200 range.
  5. Jan 17, 2025 at 7:52 AM
    Owenhall
    Owen
    Lift 33s
    Ok that will probably do that in the future.
  6. Jan 18, 2025 at 6:16 AM
    Owenhall
    Owen
    Lift 33s
  7. Jan 18, 2025 at 7:03 AM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    I would either buy one used, from Rockauto, or just have a driveline shop replace the bad splined section.
  8. Feb 12, 2025 at 9:02 PM
    Owenhall
    Owen
    Lift 33s
    Anyone have experience with performance driveline?
  9. Feb 12, 2025 at 10:07 PM
    airkewled
    airkewled Well-Known Member
    Kevin
    Moab
    2006 Tacoma DCSB
    +1 for your local driveline shop. Been there. These guys do driveshafts day in day out 365, if you've got one even semi-local, go that route.
