Aftermarket DRL Module Install 2008 Imported from USA
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Airman 415, May 12, 2024.
  1. May 12, 2024 at 7:38 PM
    Airman 415
    Airman 415 [OP] New Member
    Brian
    Head Mechanic on my sons Tacoma 06
    Has anyone experienced with installing aftermarket DRL modules.I have it all wired and it works except I’m wondering where you might have connected the green relay trigger wire to. It needs a source of high power when the ignition is in the second “on” position.
    I’m hoping to not have to run a wire back into the cab to the ignition switch as I’ve already fixed up some previous fuckery in there and the dash is all put back together.
    Is there a source of power under the hood in the fuse box that I can grab? If so I will use the same source for the light bar kit that is also installed. Right now it is hot to the battery which works but the LEDs in the switch always have power and are on.
  2. May 13, 2024 at 8:59 AM
    caribe makaira
    Caribbean, Puerto Rico
    "Trigger" power, there's no IGN HIGH power in the engine bay fuse/relay box.
