Aftermarket Engine oil cooler make temp difference?
Discussion in 'Towing' started by Veggiestreettacos, Jun 3, 2022.
  1. Jun 3, 2022 at 8:25 AM
    Veggiestreettacos
    Veggiestreettacos [OP] New Member
    Galen
    2016 black tacoma
    I have a 2016 Tacoma no tow package and have installed OEM hitch, a engine oil cooler, and getting ready to install transmission oil cooler after fluid change to start towing my car to track
    After installation of engine oil cooler I drove street and highway to see if it would make a difference and the temps still pretty much follow the coolant temps these 2016 Tacoma's (no tow package) don't have the OEM heat exchangers so did I waste my time relocating filter and adding cooler to my Tacoma or with load of my car it would likely make a difference if anyone else done the same?
  2. Jun 3, 2022 at 9:58 AM
    mic_sierra
    mic_sierra Toshiba HDDVD is the future
    Elsewhere
    '21 DCSB TRD Sport 4x4 Auto
  3. Jun 3, 2022 at 11:43 AM
    Veggiestreettacos
    Galen
    2016 black tacoma
    I'm talking about the engine oil actually haven't installed the trans cooler yet
  4. Jul 6, 2022 at 10:22 AM
    Jowett
    Jowett Well-Known Member
    Brian
    North Adams, MA
    Engine oil temp is calculated by the ECU, there no actual sensor... adding the stock cooler will surely have the benefit of dropping engine oil temps some.
    AxisCab likes this.
  5. Jul 17, 2022 at 9:05 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    This was a after market engine oil cooler?
    Did you install a oil temperature gauge?
    Is the cooler controlled via thermostat? The down side without a thermostat is in real cold weather the oil takes longer to get up to temperature
    I can see a big difference in oil temperature but my Tow vehicle is a 7.3 Ford.
