Aftermarket exhaust idle issues.
Discussion in 'Performance and Tuning' started by ChristianB, Jun 4, 2012.
  1. Jun 4, 2012 at 4:49 PM
    ChristianB
    ChristianB [OP] Member
    Christian
    Vancouver Island
    Hey everyone. A few days ago i installed a Flowmaster American Thunder exhaust system on my 2012 Tacoma. I noticed that it is idling a lot lower, it's idling roughly at 750, after i have driven it a bit and its warmed up. Prior to installing the exhaust it would idle at like a grand warmed up. I also notice shifting gears is different, when i might be shifting into say 4th i could still be in 3rd, because the rpms are lower. I am not sure if this is normal or if the internal computer needs time to recallibrate the new exhaust, but anyone who might have had the same issues any help would be greatly appreciated. Thanks.
  2. Jun 4, 2012 at 4:51 PM
    austinramsay
    austinramsay Well-Known Member
    Austin
    Yuma, Arizona
    2001 Tacoma TRD Doublecab
    Weird but just drive around with it for a little and maybe it will change? But my 96 v6 idles around 750, so thats alright.
  3. Jun 4, 2012 at 4:52 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Any check engine light?
  4. Jun 4, 2012 at 5:01 PM
    ChristianB
    Christian
    Vancouver Island
    I noticed it a few days ago and thought maybe if a drive around a little it might straighten itself out maybe it was just the truck adjusting but still idling low.
    No check engine light. It doesn't sound like it's going to stall out either, it is still idling smooth. Just seems a little low, at least compared to when the stock exhaust was on.
  5. Jun 4, 2012 at 5:56 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    How long have you had the truck?
    Also, it sounds like maybe they disconnected the battery during the install. Then after you got it back and drove it around, the computer learned all of its parameters, and now drives like it should.
    Since it is idling smooth, I would say that it is working just the way it is supposed to.
    Mine idles between 700-800 normally.
  6. Jun 4, 2012 at 6:02 PM
    ChristianB
    Christian
    Vancouver Island
    I have owned the truck since mid november. I installed the exhaust system myself. I had not disconnected the battery when it started idling lower. Then i heard disconnecting the battery will reboot the computer, so i tried. It changed nothing.
    Is yours stock exhaust? or aftermarket? The only reason i am slightly concerned is that it wasn't idling this low prior to installing the exhaust. If it's normal, it's normal right, i am just curious if anyone else had this happen or if it can be tweaked.
  7. Jun 4, 2012 at 6:14 PM
    ChristianB
    Christian
    Vancouver Island
    It just seemed a little odd to me so i wasn't too sure. I was so used to driving the truck prior the the exhaust that i shift gears based on memory and feeling, i dont look at the rpms too much but when i was shifting like i normally would it felt gutless in comparison. Then I started paying attention to the rpms, and noticed they are lower at speeds where they would have been higher previously.
  8. Jun 4, 2012 at 7:20 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Seems to me that it is running better. o_O
  9. Jun 11, 2012 at 10:22 AM
    Ugly Betty
    Ugly Betty Well-Known Member
    mark
    TX
    85 extra cab on propane
    1985 ex cab, 92 toyota pickup, 95 4runner
    i also had this happen on mine when i installed the magnaflow catback myself, and i did disconnect the batt while i did mine cuz they said to in the instructions.
    my rpms at idle are the same as yours, ive been told its because my new exhaust is 3in diameter and the stock is i think 2 1/2 so it has less back pressure and can "breathe" a little better. i like the lower rpms its using less gas idling lower.
