Aftermarket fan clutch?
Discussion in '1st Gen. Tacomas (1995-2004)' started by SmogSUX, May 14, 2012.
  1. May 14, 2012 at 1:13 PM
    SmogSUX
    SmogSUX [OP] No Money. No Love.
    Sacramento
    96 Tacoma Manual 2.7L 4x4
    Wheelers 5-Pack w/ AAL, ToyTec 1" Shackles, 10" 5125's, 5100's w/ ToyTech Springs, Braided Steel Brake Lines, AFE Filter, BAMF Sliders
    Just wondering if any of you have had any experience with an aftermarket fan clutch. I've got a crazy loud squealing noise that the P/O thought was his fan belts, but I'm 99% sure it's the fan clutch.
    Now I'm wondering if anyone has had experience with the $50ish fan cluthes you can get at Kragen, online, etc, or if they're garbage and if I should just shell out the $140 for a Toyota OEM one.
  2. May 14, 2012 at 1:16 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    most squeals at the front of the engine, are the idler pullys. Check those first.
  3. May 14, 2012 at 1:22 PM
    02sr5trd
    02sr5trd Well-Known Member
    Donnie
    Ohio
    02 SR5 TRD 4x4
    Deckplate Mod, AFE Pro Dry filter, Xcelerator 14'' muffler, AAL, 5100's @2.5, Kenwood DD HU, Alpine speakers.
    I have a brand new after market I bought and never put it on. I went with oem. 3.4 l. Let me know if u need it.
  4. May 14, 2012 at 1:24 PM
    PrezidentRedz
    PrezidentRedz Uncivilized Creations Prez
    Redz
    Owings, MD
    00 Taco 4x4 Xtra Cab, Locked and Lifted.
    Custom Everything! WHAT º¿º
    Go Electric if your going to yank the fan off.
  5. May 14, 2012 at 1:28 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Squirt water on the belt. If the noise goes away, it's the belt, or a misaligned pulley. If it stays, oil the idler and tensioner pulley, one by one. If it stays, it's probably the fan.
    Get a mechanic's stethoscope to listen to the alternator and water pump bearings. $7-20 ish. It'll help you isolate the noise.
  6. May 14, 2012 at 8:32 PM
    SmogSUX
    Sacramento
    I'll look (listen) more in depth, but it's for a 2.7.
    The only diagnosing I really did was noticed that it only squeals upon startup and the second it goes away I hear the clutch fan catch and start blowing air for a second. Does it every single start up warm or cold and goes away within 30 seconds. When it's warm it'll go away in like 5 seconds.
  7. May 14, 2012 at 8:40 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Water pump bearing maybe?
    I've used a couple parts store clutches. They seemed to work okay. Never put a lot of miles on them though, by the time I needed one replaced the vehicle had a lot of miles on it already.
  8. May 15, 2012 at 5:06 AM
    PrezidentRedz
    Redz
    Owings, MD
    very possible the belt it just loose. I had the same issue on my 2.7 PS pump belt.
  9. May 15, 2012 at 11:18 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    A properly working clutch fan will be engaged with a cold startup. Until the silicone inside the clutch heats up, then it disengages.
    Let is know what else you find.
  10. May 15, 2012 at 1:17 PM
    SmogSUX
    Sacramento
    That's why I figured it was the clutch fan. Only when the squealing went away would I hear the clutch fan engage and push some air. I'm gonna check it out tomorrow though in depth...so embarrassing every time I start my truck.
