Aftermarket FM Antennas, Suggestions Needed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12TRDTacoma, Nov 13, 2016.
  1. Nov 13, 2016 at 9:55 AM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Looking for a good aftermarket FM antenna to do a relocate to either the bed area or even the interior of the truck. Either way. I want my standard radio back. It's been too long.
    I'd like some suggestions please.
  2. Nov 13, 2016 at 11:49 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Nothing huh? It's a project I'd like to take on today if I can get a good one.
  3. Nov 13, 2016 at 11:58 AM
    Benzdriver81
    Benzdriver81 Making it fool-proof will just make a better fool
    Kevin
    PNW
    05 DCLB Sport
    Ya....I got nothin'.
    Only thing I've heard of as far as any "relocated antenna" would be putting in a CB antenna for a CB radio, and getting a splitter so both radios can use the same antenna
    :notsure:
  4. Nov 13, 2016 at 12:48 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I never thought of that. I would do it but I really don't like CB radios too much as I feel they look kind of tacky in the interior.
  5. Nov 13, 2016 at 12:50 PM
    Benzdriver81
    Kevin
    PNW
    05 DCLB Sport
    True, depends on how they're mounted. At any rate, you can use a CB antenna and just get a cable with a Motorola connection and hook it straight to your factory radio.
  6. Nov 13, 2016 at 1:00 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Is it an amplified antenna? Those things are pretty big aren't they?
  7. Nov 13, 2016 at 3:37 PM
    Benzdriver81
    Kevin
    PNW
    05 DCLB Sport
    Not, not amplified. The thicker antennas can be pretty big, or you can get the whips, which are pretty skinny.
  8. Nov 14, 2016 at 12:23 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Oh I gotcha. See where I live the antenna needs to be amplified as they are apparently removing radio towers so there are less and less to spread such a wide distance in between.
  9. Jun 3, 2017 at 2:13 PM
    G.T.
    G.T.
    CONUS
    Had no idea that this existed and found this thread during my search today. Will this only work for FM, or will I be able to pull AM signal as well?
    Benzdriver81[QUOTED] likes this.
  10. Jun 3, 2017 at 2:57 PM
    wsurunner
    wsurunner Well-Known Member
    2015 Pyrite Mica DCSB
    I bought a TuneTrapper to replace my factory antenna. I also needed a Metra adapter.
    Unfortunately I don't listen to radio much so I don't have any before/after comparisons on reception. Right now I have it shoved up under the dash on the passenger side; contemplating moving it out to the front bumper area if I'm unhappy with the reception as there's a lot of room up there and you can get reasonable distance between the antenna and metal (which can impede reception).
  11. Jun 3, 2017 at 5:48 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Although it does work somewhat, cb and am/fm antennas are designed around different sets of frequencies.
    Each would do better with their own antennas.
    As for the bad reception, check the mounting of the antenna. Clean out any crud. if there's nothing wrong with the existing antenna, look for a new head unit with a better tuner.
  12. Jun 4, 2017 at 8:29 AM
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
    I got one of these last October at Walmart as the OEM antenna would not fit under our flat roof carport; it comes with adapter studs that fit the OEM base, I tossed the supplied base and cable into one of my junk drawers--who knows what you might need some day.
    It is 13" long--1/9th λ at 100 MHz (the middle of the FM band) but while not an optimal length (29.5" is 1/4 λ) it does work well here i the flatlands of NE Florida. I get good reception of stations from Jacksonville and Daytona. both 50+ miles away; even when its bent backwards at 85 mph.
    For $8.97 you cannot go too far wrong...
    dborrer likes this.
  13. Jun 5, 2017 at 9:43 AM
    Benzdriver81
    Kevin
    PNW
    05 DCLB Sport
    It should work for all three at the same time. I've been wanting to install a CB antenna in the stock antenna location (to keep the factory look) but use that one antenna for both radios.
    Here's the adapter I found:
    https://smile.amazon.com/dp/B00HPH23LA/_encoding=UTF8?coliid=IF3UBLJAQAGZE&colid=M0WCV00C5FGX
  14. Jun 5, 2017 at 10:05 AM
    G.T.
    G.T.
    CONUS
    Thanks for that, I'm having to go a different direction as I have fiberglass fenders and will be making a snorkel that will end up deleting the factory antenna from its location.
  15. Jun 5, 2017 at 10:09 AM
    Benzdriver81
    Kevin
    PNW
    05 DCLB Sport
    Ya, that was my original plan. But recently, my factory antenna snapped off and I can't get the broken part of the shaft out of the mount. So now I have an excuse to get a new CB antenna and mount it in the bed :D
    G.T.[QUOTED] likes this.
  16. Jul 25, 2017 at 8:50 PM
    beertimecontinuum
    beertimecontinuum What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
    Just ordered along with this plug for the fender :cheers:
    KTM753 and Benzdriver81[QUOTED] like this.
  17. Jul 25, 2017 at 11:27 PM
    Syphrum
    Syphrum Well-Known Member
    Thousand Oaks
    2006 DCLB
    BFF Hybrid Front Bumper BFF High Clearance Rear Bumper - soon HomerTaco Grill BAMF Sliders CMC - soon Bilstein 6112/5160 Dakar Leaf Pack - medium Total Chaos UCAs OEM LCAs - thanks @gunny1005 ! Retrofit Smoked Projector Fronts/LED Rears - soon - thanks @LSC15 ! WeatherTech Floormats Sony Touch Receiver
    Limited choices, I replaced a broken OEM with a stubby.
    Bad news. I lost several stations
    Good news. None of them were mine, wife lost most of the pop n country stations :headbang:
    KTM753 and SpeedwayTaco160 like this.
  18. Jul 26, 2017 at 1:25 PM
    Benzdriver81
    Kevin
    PNW
    05 DCLB Sport
    OOOoooooo!!!!!!
    Let me know how it turns out! I was recently given a pair of 2' CB antennas, so now I'm trying to figure out how I want to mount them (Dual setup? Just 1 in the factory location? I don't know anymore....)
  19. Aug 24, 2019 at 3:33 PM
    Syphrum
    Thousand Oaks
    2006 DCLB
    Update. Added fiberglass fenders and stubby is no longer compatible.
    Been relying on iHeartRadio/Android auto.
    Switching to a 50 Cal bullet antenna mounted to the hood hinge soon
  20. Aug 21, 2020 at 4:28 AM
    dborrer
    dborrer Well-Known Member
    Mr. Dan
    St. Augustine, FL
    2006 Tacoma TRD Sport 4x MT
    2018 new Frame (thank you Rust!), FJ T-case swap. SPC(LR) UCAs, Bilstein 5100s front - rear, OME 883 at 0, HeadStrongOffRoad 3 leaf progressive AAL, MESO custom 2nd gen (Red/White) LED dome & Ultimate Maps, Spyder Halo Projector w LEDs (which SUCK), Spyder LED tails
    yeah St. Augustine!! I'm on A Street.....
