Aftermarket Front Bumper Weight
Discussion in '3rd Gen. Tacomas (2016-2023)' started by hahnster, Nov 21, 2022.
  1. Nov 21, 2022 at 12:59 PM
    hahnster
    hahnster [OP] Well-Known Member
    2022 Tacoma 4x4 V6 AT
    3" Lift, TRD Pro Grill, TRD Skid Plate, 285x70/r17 BFG KO2's, LED Headlights, Rock Sliders
    I have a 2022 Tacoma SR, V6, 4x4 with a rough country 3" lift kit. I am considering an aftermarket front bumper that weights between 70 and 100 lbs. Someone told me that it might cause my front end to drop a little due to the extra weight. Has anyone had this experience of the nose of the truck dropping a little due to the extra weight of an aftermarket, steel bumper?
  2. Nov 21, 2022 at 1:03 PM
    skeletron
    skeletron Disgraced Member
    Clark
    Sakerlina
    2020 TRD Broh
    I think droop fears are overblown. Your stock springs are something like 650#/inch, meaning it requires that amount of weight to push down 1 inch. An additional 100# from the bumper would result in a very small change.
    hahnster[OP] likes this.
  3. Nov 21, 2022 at 3:10 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    It will some yeah, have someone push down on the front bumper and see if it’s acceptable to you.
    BamBeds likes this.
  4. Nov 21, 2022 at 3:13 PM
    Extra Hard Taco
    Extra Hard Taco Well-Known Member
    R.J.
    Devil's Island
    2012 Tacoma TRD OR, 2007 DC (sold), 2003 TRD OR (sold)
    ARB Bumper, SOS sliders, SOS rear bumper, SOS skid plate. OME Lift. Some other stuff.
    You'll more than likely lose about a quarter of an inch in ride height on the front.
  5. Nov 21, 2022 at 3:27 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Yes your front end ride height will decrease if you add a heavy front bumper. It also decreases when you get in the cab. You can estimate the difference with some simple physics. The stock coil springs have a spring rate of about 700 lb/in. The IFS has a motion ratio of about 2:1. Therefore every additional 100 lbs on the front springs will cause a drop in ride height of about (100 lb / 1400 lb/in) * 2 * 2 = 0.29”.
  6. Nov 21, 2022 at 4:43 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Mathematically maybe but my truck lost about 1/2” after installing a low-pro and winch which together weighed about 180 lbs. granted thats more than 100 but more than what the spring rate would suggest.
    That’s one of the contributing factors to why I went up to 750 when I swapped for a full bumper and added skids etc
  7. Nov 21, 2022 at 4:49 PM
    gudujarlson
    Minnesota
    1/2” drop from 180 lbs is right inline with the estimate I posted.
    J Williams likes this.
