Aftermarket front bumpers damaging mounting location?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by h2beezy, Dec 3, 2023.
  1. Dec 3, 2023 at 9:41 AM
    h2beezy
    h2beezy [OP] Well-Known Member
    2022 TRDOR
    I've heard that there is a common issue with heavier bumpers coming loose because where they bolt into on the frame for the Tacoma is especially weak.
    I'm planning on putting a little CaliRaised Stealth bumper about 77lbs on. Am I safe or should I look into reinforcement? I'm not having a winch installed either.
  2. Dec 3, 2023 at 10:34 AM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    where is this a common issue?
  3. Dec 3, 2023 at 10:59 AM
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    jmauvais, h2beezy[OP] and Chew like this.
  4. Dec 3, 2023 at 5:57 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    With no winch there should be no problem with bending or falling off bumpers. For your occasional tug, just use the supplied hook on the passenger side, it is not a great attachment location, but it will do, I prefer a secure shackle.
    The bending that I have seen on every Tacoma that has winched often is definitely prevalent, but have not seen one fail, or even close to failing. In my opinion the bracket type reinforcements are probably just hiding or rather covering up the problem of the bent mounting plate. Toyota made the attachment for a bumper, which gets pushed into the truck, not pulled away and thus it is not suitable for heavy pulling without some deformation of the bumper attachment plates. Mine were bent until I removed them completely and welded on new 1/4" plate attachments using 6 bolts, but that was another fiasco.
    h2beezy[QUOTED][OP] likes this.
  5. Dec 4, 2023 at 4:58 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    It really has nothing to do with the weight of the bumpers. What your reading online is people bending the frame horns winching from the bumper. The plate will pull away from the truck on a heavy winch pull without reinforcement.
    Clamping the bumper to the frame reduces the chances of that happening.
    Our reinforcement brackets fully clamp the bumper into the frame reducing the stress on the mounting point while winching.
    https://www.bayareametalfab.com/FBR...inforcement-brackets-2005-to-2023-_p_142.html
  6. Dec 4, 2023 at 5:27 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    The Caliraised design mounts to only the 6 tiny studs of the stock crash bar mount. Therefore a reinforcement bracket is recommended:
    One small obstacle you may encounter is the carry-through structure for the shackle mount may be close to the stud holes:
    This may require trimming the flange of whatever reinforcement bracket you get. Easy enough with an angle grinder, but be prepared to do it.
    boston23 likes this.
  7. Dec 4, 2023 at 5:42 AM
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
  8. Dec 4, 2023 at 6:04 AM
    tacoma04
    tacoma04 Retired to the lake
    Bruce
    Tennessee
    2017 TRD OR DCSB BBP
    You need to look at how the bumper mounts. As JLee said, the mounting point needs reinforcing.
    My bumper is by At The Helm and it uses a support bracket back along the frame that bolts through the frame. It reinforces the mounting point on both sides.
    cmonjack and eurowner like this.
  9. Dec 4, 2023 at 9:02 PM
    Toycoma2021
  10. Dec 4, 2023 at 9:24 PM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
  11. Dec 5, 2023 at 4:22 AM
    PTPinETN
    PTPinETN Well-Known Member
    Alan
    ETN
    While I haven’t had any hard pulls yet, I have wondered about this same thing, not saying reinforcement isn’t needed, just haven’t heard of any bumper attachment failing.
    So, the question is: Does anyone have first hand knowledge of someone bending their bumper to truck attachment during winching operations?
  12. Dec 5, 2023 at 7:01 AM
    MR E30
    MR E30 Well-Known Member
    Michael
    Wherever it's parked
    2021 Silver TRD OR DCLB w/ AluCab and All the Mods
    C4 also makes a reinforcement bracket that I would recommend. Ties into the frame with three additional bolts on each side. (1) through the frame and (2) into it from the bottom.
    [​IMG]Tacoma Front Bumper Install by Michael Rickerd, on Flickr
    CaptainBart45, TailHook and eurowner like this.
  13. Dec 5, 2023 at 7:17 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    First-hand? No. But I've seen enough pictures of bent stud plates posted on TW. The frame feature is carried over from the 2nd gen, so there are multiple failures documented over the years. Example from 5 minutes of Googling:
    https://www.tacomaworld.com/threads/bumper-mount-deformation-repair.575030/
    https://www.tacomaworld.com/threads/front-bumper-mount-failing.569632/
    https://www.tacomaworld.com/threads...t-much-of-a-build-thread.337259/#post-8935425
  14. Dec 5, 2023 at 3:02 PM
    PTPinETN
    Alan
    ETN
    Close enough, looks like I’ll be adding braces.
    Thanks for your Google efforts.
    Anyone know if any of these additional braces will work with a SSO slimline?
  15. Dec 5, 2023 at 3:04 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    ^The SSO frame plate is very thick, leaving no extra thread on the studs to sandwich a brace in. None of the braces works with the SSO slimline unless you punch out the studs and install longer studs.
  16. Dec 5, 2023 at 3:31 PM
    PTPinETN
    Alan
    ETN
    Noticed this during install
    Not opposed to doing this for the peace of mind, with longer studs will any of the braces work?
    Thanks for your knowledge.
  17. Dec 5, 2023 at 3:51 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    ^With longer studs they should all work. You may need to trim the front flange on the braces to clear weld beads, but that's just a few minutes with an angle grinder.
    • Some of the braces anchor to the sway bar pillow block bolts. That adds thickness if you're already have sway bar relocation blocks, and can cause the sway bar to chafe on the front skid. I don't run a front sway bar so I don't have this problem.
    • All of the braces except the BAMF ones may clash with remote resi mounts, requiring trimming or holes to be drilled. My coilovers don't have remote resis so I don't have this complication.
    • All of the braces except the BAMF ones require trimming the plastic fender liner if you haven't done it already, since the braces reach all the way back along the frame.
    Toycoma2021 likes this.
  18. Dec 5, 2023 at 5:03 PM
    TailHook
    TailHook You just gotta keep livin' man, L-I-V-I-N
    Alan
    Southern UT
    2018 TRDOR 4X4, 2007 Sequoia 4X4
    My CBI bumper has identical brackets :cheers:
    MR E30[QUOTED] and CaptainBart45 like this.
  19. Dec 5, 2023 at 5:17 PM
    PTPinETN
    Alan
    ETN
    Thanks again for the info
  20. Dec 5, 2023 at 5:18 PM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    Yep, my Victory 4x4 has the same too.
    MR E30 and TailHook[QUOTED] like this.
