Aftermarket gill/pcs sencor
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TLS, Jan 17, 2025.
  1. Jan 17, 2025 at 4:42 AM
    TLS
    TLS [OP] Member
    2022 Tacoma TRD off road
    Pedal comander and front grill so far
    So I've put a aftermarket Baja mesh grill on my Tacoma and had to move the pcs sensor to the bottom of the grill.now I can dive about 10 miles before it shuts off my pcs system and tells me to clean sensor...any thoughts on this?? Wondering if it needs recalibration or something..
  2. Jan 17, 2025 at 6:00 AM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    Yes it needs to be recalibrated.
    Hope your wallet isn't empty.
    Phlogiston and Chew like this.
  3. Jan 17, 2025 at 6:04 AM
    TLS
    TLS [OP] Member
    Ugh.thanks..i talked to one of the local toy dealers gonna be like 200-250 to do so.sure makes for an expensive grill upgrade.
    dryheat likes this.
  4. Jan 17, 2025 at 8:34 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    You can try shimming it yourself first. Lots of info on here about it.
  5. Jan 18, 2025 at 5:21 AM
    TLS
    TLS [OP] Member
    Thank you for the shimming idea.so far has cured the issue with pcs shutting off.thanks again
  6. Jan 18, 2025 at 2:53 PM
    TLS
    TLS [OP] Member
    Well back to the drawing board or the dealer the shiming didn't cure the issue of pcs shutting off again after driving a while..thanks anyway for the thought
  7. Jan 18, 2025 at 6:35 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
  8. Jan 18, 2025 at 6:48 PM
    TLS
    TLS [OP] Member
    That's a good thought I'll give it a shot.thank you
