Aftermarket headlight options for the SR model
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BaseTaco2.7, Dec 15, 2020.
  1. Dec 15, 2020 at 12:38 PM
    BaseTaco2.7
    BaseTaco2.7 [OP] Well-Known Member
    So i have a 2018 SR 4 cylinder with the stock headlights and wanted to upgrade to some after market LED headlights that will plug and play. Any good options out there that will fit this SR model??
    4doorbeater likes this.
  2. Dec 15, 2020 at 12:39 PM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    There are no plug and play led headlights for the sr model. The sr uses all halogen bulbs and the wire harness is different. You can buy an led adapter here on tw.
    BaseTaco2.7[OP] likes this.
  3. Dec 15, 2020 at 12:45 PM
    BaseTaco2.7
    Oh ok so any aftermarket headlights will work as long as i get an LED adapter?
  4. Dec 15, 2020 at 1:01 PM
    Tacomike18
    J
    As far as I know, yes. There are a few threads here on tw that explains it.
  5. Dec 15, 2020 at 1:03 PM
    BaseTaco2.7
    Can you link those threads if you dont mind
  6. Dec 15, 2020 at 1:07 PM
    Tacomike18
    J
  7. Dec 15, 2020 at 1:09 PM
    BaseTaco2.7
  8. Dec 15, 2020 at 1:10 PM
    Tacospike
    Two Trucks
  9. Dec 15, 2020 at 1:12 PM
    Kairide
    Kairide Well-Known Member
    2020 White SR5
    Could switch out bulbs for Hikari Ultras or the new Morimoto 2 Stroke 3.0.
  10. Dec 15, 2020 at 1:13 PM
    Kairide
    2020 White SR5
    Tacospike[QUOTED] likes this.
  11. Dec 15, 2020 at 1:13 PM
    kmorgan3
    kmorgan3 Redside Electric, LLC | VLEDS
    Kyle
    PNW
    2020 4Runner SR5 Premium | RAM 1500
    For less cost and headache of converting to the OEM LED or other headlight you could probably send your stock headlights in for an LED retrofit from @no vtec 4me
  12. Dec 15, 2020 at 1:14 PM
    Tacospike
    Two Trucks
    More plug and less play I guess :rofl:
    Kairide[QUOTED] likes this.
  13. Dec 15, 2020 at 1:29 PM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    This won't give you LED headlights, but you could replace your headlights with OEM TRD Pro halogen black headlights 17-19. You would have a non functioning LED DRL, and still no LED headlights. You could always add LED bulbs if you wanted to.
  14. Dec 15, 2020 at 1:34 PM
    sandiegohasthebesttacos
    sandiegohasthebesttacos Well-Known Member
    the morimoto xb, alpharex, and tacomabeast 2020 OEM clones are plug and play for SR.
    install video of morimoto xb on SR - https://www.youtube.com/watch?v=zqQ0zca3CD0&ab_channel=HeadlightRevolution
    these vland alibaba ones that can be found on ebay are plug and play as well.
    (not my pic)
  15. Dec 15, 2020 at 1:40 PM
    BaseTaco2.7
    Did that but with Auxbeam. I want to get the projector headlights with sequential turn signal from tacoma beast
  16. Dec 15, 2020 at 1:55 PM
    BaseTaco2.7
    This vid helped alot. Thanks! Now, will the tacoma beast OEM clone be installed the same as these morimotos or differently?
  17. Dec 15, 2020 at 2:03 PM
    more or less the same. it should come with its own wiring harness. there's no universal one-harness-works-for-all solution. you can ask them for more details.
    the tricky part of the SR and aftermarket headlights is the factory wiring's DRL and turn signals are the same so you have to power the aftermarket's DRL separately. sometimes that changes the functionality of the headlight a bit. for example, the vland ones that i posted above is what i have and on the DRL spot on the stalk only the amber turn signals turn on. to get the white DRL you have to turn it to the parking lights position. the old depo headlights i used to have there would be a 3 second delay from when you'd turn on your blinkers and see your turn signal because of the module to get the LED DRL's to work.
    i don't know about the particularities of the morimotos or tacomabeast ones since i've never owned them.
    edit: obligatory "before you buy new headlights you should read crash's thread" - https://www.tacomaworld.com/threads/3rd-gen-hid-vs-led-vs-halogen-h11-projector-headlights.589465/
  18. Dec 15, 2020 at 2:17 PM
    BaseTaco2.7
    Oh ok gotcha. Thanks for your help bro!
  19. Jan 29, 2021 at 9:01 AM
    DetroitDarin
    DetroitDarin Specified
    York County PA
    Scratches and Whatnot
    hope this isn't too late - I have the depots for my second gen, and they are without a doubt the worst headlights I've experienced - and I used to drive cars made in the 60s and 70s. My headlights would shine only about 15 feet in front of the truck - that was the hotspot; my driving lights shined farther and brighter. They looked cool, they looked great - but they performed HORRIBLY.
  20. Jul 5, 2021 at 2:26 PM
    Tater1727
    Tater1727 Active Member
    Nate
    2021 Tacoma SR
    Did this work for you? I have a 2021 Sr and looking to go LED with DRLs
