Aftermarket Headlights
Discussion in 'Lighting' started by Bobwein83, Jan 17, 2021.
  1. Jan 17, 2021 at 9:58 AM
    Bobwein83
    Bobwein83 [OP] Member
    2015 Magnetic Gray TRD Sport
    Bilstein 5100, 1" Rear Block
    Regarding aftermarket headlights... Okay, so I’m aware of the search feature and have not yet found a direct answer to my specific question.
    in general I understand that the consensus is that retro mod on oem is going to give you the best results. However, aside from concerns of moisture, how would aftermarket headlights brightness from, say, Tacomabeast or Spyder compare to standard original non projector oem?
    I understand that they will not be as bright as a high quality retro mod, but I don’t want the super-bright-nuclear bomb-lighting. As long as lighting is on par with oem output - currently just standard halogen - can I at least expect the same comparable output from spyder, etc?
    again, I don’t care to enter into competitive headlight brightness competitions, just to maintain output of oem.
    thanks.
    edit: to better clarify, I want to upgrade the headlights simply for the aesthetic look. Additionally, the lense is fogged up, and so wanting to replace that component more than anything, and this is also why I’m not interested in modding for more intense light. Note: yes, I have performed a full wet sand process on the outside clear lenses, then sealing with a clear coat with uv protectant. This lasted about 2 year, until becoming cloudy again.
    so, yes, I want new headlights, not to mod.
  2. Jan 17, 2021 at 11:11 AM
    outxider
    outxider Never stop exploring. Rest in Paradise Big Bro.
    Sang
    East Bay, CA
    06 DCSB 4x4
    A few mods here and there and counting....
    Toy_Runner likes this.
  3. Jan 17, 2021 at 1:47 PM
    Toy_Runner
    Toy_Runner Well-Known Member
    99 4Runner SR5
    3" OME lift, heavy coils f/r 3/16" steel skids Modified Coastal Offroad diy bumper 5spd swap ('98 donor)
    For 2nd gen upgrades, go for a relay harness and a high quality bulb, if you're not going for a D2S retro like an rx350.
    All of the aftermarket lamps are poor performers in comparison.
    outxider likes this.
  4. Jan 17, 2021 at 3:18 PM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    The optics in the lights you mentioned are just awful. Both are a significant downgrade from OEM from a performance standpoint.
    crashnburn80 likes this.
