aftermarket HU and steering wheel controls
Discussion in 'Audio & Video' started by bmgreene, Feb 18, 2015.
  1. Feb 18, 2015 at 4:54 PM
    bmgreene
    bmgreene [OP] Well-Known Member
    Brian
    L.A. Westside
    2010 PreRunner V6 SR5/OR
    Alcan Leaf Packs, OME884 Coils, 5100 shocks, U.S. Offroad Winch Mount w/Winch, Trail Gear Rear H/C Bumper, Prinsu Cabrack, DIY custom in-bed storage/sleeping deck, Sway bar delete, hidden "snorkel" intake mod, In-dash CB, Bestop Supertop, Undercover Swingbox, hood lifters, assorted lights and front spotting camera
    Does anyone know if there's a brand/line of single-DIN aftermarket head units which are compatible with Toyota steering wheel controls out of the box?
    I'm looking to replace my system to make room for a CB and because the factory unit seems to have some kind of a loose connection in it somewhere which makes it shut down randomly. I'm not looking to get elaborate, but would like to retain the wheel controls, and the adapter kits out there cost more than the head units I'm currently looking at, so it's not worth the price if I have to go that route.
  2. Feb 18, 2015 at 6:11 PM
    timothom
    timothom Well-Known Member
    2014 Tacoma Access cab sr5
    Kenwood DMX7705S PrecisionPower Phantom 900.4 Alpine type-r 8" Image Dyanmics CXS64.2
  3. Feb 20, 2015 at 9:33 AM
    bmgreene
    Brian
    L.A. Westside
    thanks,
    For some reason it didn't occur to me to check Amazon for the adapter, I can live with the $50 that amazon wants, as opposed to the $140 that Crutchfield lists it at...
  4. Feb 20, 2015 at 9:43 AM
    firestorm
    firestorm Active Member
    Calgary, Alberta
    2011 Tacoma DBL Cab
    I can confirm that the Axxess unit works perfectly with my Pioneer AppRadio 4 in my 2011 Tacoma.
  5. Feb 20, 2015 at 4:56 PM
    timothom
    They also have a wireing harness you can buy for like 5 bucks that will plug into the stock plugs, so you don't have to cut anything. It worked fine on my 2014 Tacoma
  6. Feb 24, 2015 at 7:44 AM
    Babs
    Babs Well-Known Member
    Asheville NC
    TRD V6 6spd
    Scratches preinstalled from original owner
    It's some money, but I'm using a PAC SWI-CP5 in another car which is programmable via device app for the vehicle with connection instructions for about any car on the planet and all aftermarket head unit brands. Works like a champ. Also gives easy customization on the controls, such as long-press, etc. Disclaimer: I've not used it in the Tacoma, yet, but I suspect it'd be great.
  7. Feb 24, 2015 at 10:51 AM
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    If you go with the Access definitely get the add-on harness, makes things really easy.
  8. Feb 24, 2015 at 1:36 PM
    NOCENTS
    NOCENTS Well-Known Member
    Arm pit of Cali
    08 TRD DC needin some lovin
    loooooong list of mods coming as soon as I finish the audio/video system
  9. May 10, 2020 at 7:52 AM
    ScottyDoesn’tKnow92
    ScottyDoesn’tKnow92 New Member
    Scott
    2010 Barcelona Red TRD off road access cab
    So I have the Axxess unit but it doesn’t work, it doesn’t even have the led lights like in the instructions. Do you think they sent me the wrong one?
  10. May 12, 2020 at 11:06 AM
    bmgreene
    Brian
    L.A. Westside
    Mine hasn't worked since I spliced it in, but I've been too lazy for a few years now to pull the dash back apart to try to fix it.
    I think there might either be a mistake in the installation instructions or some of the wire coloring might be a little confusing/ambiguous and since I clearly didn't connect something to the right wire somewhere. I've got a JVC single-DIN head unit (used the other half of the space to put in a Cobra 18WXSTII in-dash CB).
