Aftermarket Hub Bearing Assembly
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nammer, Mar 10, 2013.
  1. Mar 10, 2013 at 10:52 AM
    nammer
    nammer [OP] Well-Known Member
    Nam
    Bradenton, Florida
    Wishing I had a Taco
    Does anybody have a good recommendation on what hub bearing assembly to buy? My Front Driver's side needs replacement
    I usually like to buy oem parts, but from what I read, it seems as if they sell bearings and you have to get them pressed in and out? so I figured aftermarket is the way to go, especially since this seems to be such a common problem on these trucks, leading me to think oem is crap.
    this one had a bad review about fitment
    http://shop.advanceautoparts.com/we...sembly-moog_18440257-p?searchTerm=hub+bearing
    napa?
    http://www.napaonline.com/Catalog/CatalogItemDetail.aspx?R=ATM2122437_0291655330
    timken from autozone?
    http://www.autozone.com/autozone/pa...N-6o2ny?itemIdentifier=209988&_requestid=3585
    what do you guys recommend? or any other ones?
  2. Mar 10, 2013 at 11:28 AM
    Front sight
    Front sight Well-Known Member
    SW Florida
    06 Prerunner TRD Sport
    Full OME 3"lift, LR UCA's,Destination 285/70/17's, 1.25 spidertrax, K&N drop in, 2nd filter removed, Weathertech liners, Toyota bed mat, reverse lights,Wet Oklee's, bedlights and other small stuff.
    I got the cheapest set I could find on ebay. I then took them apart-very easy- and packed them full of good synthetic bearing grease. Replace all of the seals and your good to go. 10,000 miles later I'm still good. ---I only put about 5k on my truck a year anymore. But a good portion of those miles are to hunting and fishing spots ie mud, sand, water.
  3. Mar 10, 2013 at 11:37 AM
    nammer
    Nam
    Bradenton, Florida
    i was under the impression, that if I buy a whole assembly it should be good to go with the exception of adding more grease? do I still have to replace any seals? am I retarded?
  4. Mar 10, 2013 at 11:55 AM
    Front sight
    SW Florida
    LOL, no your not retarded. The outer and inner seals seal up the bearings against water, dirt and grime. They are cheap to replace. When I did mine my inner seal was somehow tore and why my bearing went bad. I tried to find an image to show it all broken down on google, but failed lol.
    http://www.rockauto.com/catalog/x,carcode,1442967,parttype,1860
  5. Mar 10, 2013 at 12:12 PM
    nammer
    Nam
    Bradenton, Florida
    i guess wherever i get the bearing i will ask them for the seals as well,
    thanks frontsight, also can you take a look at the autozone link, and tell me if the "module" is the same thing as the "bearing assembly"?
  6. Mar 10, 2013 at 12:55 PM
    Front sight
    SW Florida
    You got it, thats it.
  7. Mar 10, 2013 at 12:57 PM
    nammer
    Nam
    Bradenton, Florida
    sorry were u saying the seal is all i need, that's it?
    or is the module is same part as the hub assembly, that's it?
    thanks again
  8. Mar 11, 2013 at 10:12 AM
    Front sight
    SW Florida
    You're going to need the bearing assembly and then the outer and inner seal for both sides. The autozone link showed the bearing assembly.
