Aftermarket injector o-rings that don't suck?
Discussion in '1st Gen. Tacomas (1995-2004)' started by csrf, Jul 30, 2023.
  1. Jul 30, 2023 at 5:11 PM
    csrf
    csrf [OP] Active Member
    I had to pull the injectors off of my 5VZ-FE in order to clean them & troubleshoot some misfire issues. Best practice is to replace the o-rings everytime you pull & reinstall the injectors. I went with the FELPRO ES70600 o-ring kit cuz the OEM o-rings are like $5 bux each, and the FELPRO kit comes with 4 o-rings for around the same price.
    I made sure to lube the o-rings with gas & slowly twist them in. They went in smoothly, no issues. Almost 100% confident I didn't pinch or damage them during installation.
    Anyway, I did a smoke test with a DIY smoke machine, and I'm pretty sure a couple of the FELPRO o-rings are leaking. Right off the bat, I noticed that they weren't as beefy as the OEM rings, and the rubber seemed to be of cheaper quality. Bottom line, these FELPRO o-rings are a bust.
    So, before going the super-expensive OEM route, I'm wondering if anyone has a source for GOOD injector o-rings at an OK price, that seal well, and that are of decent quality rubber.
  2. Jul 31, 2023 at 8:30 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    When I got my MotorWest denso "upgrade" injectors, they included a single-use packet of super lube. I had initially tried using gas as a lubricant as specified in the FSM, but that resulted in some leaky o rings :facepalm:So I tried again with the supplied super lube (after I ordered some OEM o rings) and had much better success.
  3. Jul 31, 2023 at 10:07 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Gas as a Lube No thanks !
    With the work I did having an o-ring assortment was mandatory as they get used up I just replace from McMaster-Carr
