Aftermarket Interior LED Bulbs Fitment
Discussion in 'Lighting' started by ATXJoshL, Feb 5, 2019.
  1. Feb 5, 2019 at 8:03 PM
    ATXJoshL
    ATXJoshL [OP] Well-Known Member
    Josh
    2018 Tacoma TRD Pro Black
    1-1/4” Spacers, Tires: Goodyear Wrangler Duratrac, hard bed cover, Fuelpax custom-mounted on bed rail.
    Has anyone else tried to replace your map or dome light bulbs in your Toyota? I’m wondering if anyone else has run into issues trying to make them fit.
    I have a 2018 Tacoma, but had the same issue with my wife’s 2010 FJ Cruiser.
    The aftermarket dome light bulb is shaped a little different, and acts like it’s too long.
    On the map light bulbs, the plastic is too thick to fit into the socket.
    I ended up using a Dremel and modifying the bulbs to make them fit, but it sucks I even need to. Curious if anyone else has run into this issue.
  2. Feb 5, 2019 at 9:35 PM
    RetiredRedneck
    RetiredRedneck Well-Known Member
    Bruce
    Port Moody, BC
    2018 TRD Off-Road - The Grey Ghost
    Toyota Roof Rails/Rack Toyota front Skid Plate BAKflip Hard Tonneau Cover iBoard Running Boards AVS Hood bug/rock deflector AVS Window Rain Gutters Amazon Centre Console Tray Larsen 2m/70cm antenna QYT VHF/UHF Mobile Radio Auxting LED Reverse Lights Taco Garage DMM with RAM bits-n-pieces Toyota OEM Bed Mat Interior LED Light upgrade - SuperBrightLEDS.com Pop-n-Lock OG Fabrication Centre Console Molle Panels Decals and badges removed CaliRaisedLED Amber Fogs, Ditch Lights and bumper Light Bar MESO Switch Panels AirOnBoard Switches Home Brew Auxiliary Electrics Panel
    Hey Josh,
    As luck would have it, I have given up on the stock interior lights...old eyes and dim bulbs are a bad combination. My mission tonight is to find some new bulbs
    There have been a couple postings on the "What have you done to your 3rd Gen today?" thread, but of course i can't find them, now that I need them
    Meso Customs is the Guru, and his LED replacements turn night into day...alas, he also sells out within minutes...
    I do recall that Amazon sells a couple 'kits', looking for those as we speak...as well, Superbrightleds has (apparently) direct replacements
    https://www.superbrightleds.com/veh...hicle-led-lights?make=77&model=1618&year=2018
    I haven't heard of anyone having issues with either Superbright or Amazon....
    Not sure if this helps or not...good luck
    ATXJoshL [OP] likes this.
  3. Feb 6, 2019 at 12:32 PM
    ATXJoshL
    Josh
    Someone else suggested a seller on eBay who he says he had great luck with. I saved that just in case. Either way, mine are installed now, but that doesn’t mean I might not need them in the future.
    Here’s that kit: https://www.ebay.com/ulk/itm/391823627282
    Here’s the kit I bought: https://hidkitpros.com/shop/2015-2018-toyota-tacoma-led-lighting-package/
  4. Feb 6, 2019 at 4:29 PM
    RetiredRedneck
    Bruce
    Port Moody, BC
    Thanks, Man, much appreciated...I will take a look....
