Aftermarket LCAs for 4X4 2nd Gen
Discussion in '2nd Gen. Tacomas (2005-2015)' started by iJDub, Aug 5, 2015.
  1. Aug 5, 2015 at 6:06 PM
    iJDub
    iJDub [OP] Well-Known Member
    Anyone have experiences with the following:
    Moog
    Mevotech
    Dorman
    These all seem to be equivalent OEM replacements at about half the cost...
    Looks like they have the bushings and ball joints built it too. If anyone can chime in, I'd appreciate it. Thanks.
  2. Aug 5, 2015 at 6:40 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    whats your reason for replacing the LCA? AFAIK the lower ball joint and inner bushings can be replaced. Hell they even make kits for all the rubber bushings. for upper and lower.
  3. Aug 5, 2015 at 8:14 PM
    iJDub
    Cause replacement bushings and ball joints doesn't cost that much less than replacing whole one. And I can save the headache of pressing then in and out. I'll keep my OEM LCAs and install new bushings and ball joint at my leisure for future replacement.
  4. Aug 5, 2015 at 8:53 PM
    nd4spdbh
    SoCal
    if thats the case one would question the strength of said LCA and quality of components used.
  5. Aug 5, 2015 at 9:42 PM
    Rosscopeeko
    Rosscopeeko Well-Known Member
    BC
    08 DC LB 4x4 sport
    I just replaced mine with oem off a 2014 written off truck. My originals had the bushings seized to the alignment cams. Oem parts are crazy expensive. I got both lca's and all alignment hardware for $300. I don't know about the quality of aftermarket.
  6. Aug 14, 2015 at 9:36 PM
    iJDub
    bump for more feedback
  7. Aug 16, 2015 at 7:25 PM
    rambrose1
    rambrose1 Active Member
    Fairfax, Virginia
    2006 Tacoma Base 4x4
    Just ordered mevotech today, will let you know about quality when I get them and install them.
