Aftermarket leaf springs for occasional heavy towing 2017 Tacoma?
Discussion in 'Suspension' started by polaris202, May 26, 2018.
  1. May 26, 2018 at 7:39 PM
    polaris202
    polaris202 [OP] Active Member
    2017 TRD OR AC MGM
    OME suspension kit (887 Coils, Nitrocharger Shocks, Dakar Medium Duty Leaf Packs), Proline Bed Rack, Alu-Cab Gen 3 RTT, 300 Industries USMC Grille, Mobtown Off-road front recovery bar, RCI rear hidden hitch bumper with Rigid SR-Q back up lights, RCI steel skids and sliders, ShiftSense Pro, Relentless Fabrication bed rail mounts, Rago Fabrication antenna, fire extinguisher and hood latch mounts, KCHilites Gravity G4 amber fog lights, Baja Designs Squadron Pros, Falken Wildpeaks 265/75/16, MXT400 Midland GMRS, Bearcat 980 SSB CB, Hella Supertone horns.
    To my surprise the stock leaf springs on my my 2017 Tacoma Off Road (with tow package) were neutral right off the showroom floor and only go negative from there with any weight I put in the back of the truck or hook up to tow. I occasionally tow a double axle trailer with two mowers and equipment for my side job. The weight of the trailer and gear I estimate is at 3500-3600lbs. I have looked though the posts here and additional sites online looking for a solution that would give me better load carrying and a couple inches of lift for the rear without feeling like the truck body is attached directly to the axle lol. The consensus for leaf springs seems to be Deavers, OME Dakar and Allpro. The Deavers downside seems to be their high price. The Dakars may or may not increase the load capacity and/or give any lift depending on who is giving the description, and the same for the Allpros, except for their heavy duty which seems like overkill? I will probably be going with Bilstein 5100's all the way around to offset the lift in the rear with new springs, but can't afford to super mod my truck right now. I don't want to do airbags because the stock springs are so bad they need to be replaced anyway. Are there any other suggestions or anything I am missing?
  2. May 26, 2018 at 7:42 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Might want to recheck that tow limit....
  3. May 26, 2018 at 7:46 PM
    polaris202
    2017 TRD OR AC MGM
    Oops, tow limit should have been listed as 6500. My problem still remains: my leafs bowing like a huge frown and looking like they are going to snap any second. I'm no truck expert, but those stock leafs are unnerving to look at.
  4. May 26, 2018 at 7:56 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Have you looked at doing a "add a leaf" install?
  5. May 26, 2018 at 8:00 PM
    doorsidedown
    doorsidedown Well-Known Member
    Dakars exceeded my expectations. That being said, all pro has kind of fell out of favor with a lot of people here. Not speaking from experience. Just what I’ve read.
    I had an AAL before adding my dakars and I can tell you it’s worth the extra coin to upgrade to a full pack no matter who you go with. If you’re towing or hauling extra payload, skip the AAL.
  6. May 26, 2018 at 8:04 PM
    polaris202
    2017 TRD OR AC MGM
    From what I have seen written and feedback from two popular dealers in leafs/rear suspensions, most say and AAL is a band aid to underperforming springs. Unless you are talking about adding multiple leafs, I think like the Icon RXT pack?
  7. May 27, 2018 at 6:20 PM
    Natpag
    Natpag Well-Known Member
    2017 White Tacoma TRD off-road
    I personally have the Deaver j66 which rides and flexes incredibly when the bed is empty. Throw in a load of firewood though, and its on the bump stops!
  8. May 30, 2018 at 8:17 AM
    lanceputnam
    lanceputnam Well-Known Member
    I have the OME "Heavy" Dakars on my 2018 DCSB OR and I tow my Turtleback Expo Trailer fully loaded at around 2800 lbs and it tows beautifully. Still maintains an ever so slight rake as well. I also probably have 3-400lbs of gear in my bed when towing on long trips and its been a perfect setup for me so far.
  9. May 30, 2018 at 8:30 AM
    Ricebox
    Ricebox Well-Known Member
    FL
    18' TRD Off-Road 4x4 Prem/Tech
    +1 for Dakars
