Aftermarket Locker
Discussion in '5 Lug' started by KCDuran, Feb 27, 2013.
  1. Feb 27, 2013 at 3:48 PM
    KCDuran
    KCDuran [OP] Stormtrooper
    Kyle
    South Jersey
    5 Lug'n 4 banger
    Icon/TC Mid Travel Kit, Kenwood Deck, Helix Audio System, BHLM (With Tinted Reflectors), Tinted Taillights, Satoshi Grill (color matched to super white), Stormtrooper sticker, Air Force sticker HUA! Re colored gauges (White numbers and ODO with Blue Needles) Magnaflow Glasspack Muffler, Stainless steel exhaust tip, 8k HIDs, LED Satoshi, Eye Lids, ARB locker (4.10 Gears), 8k FOG HIDs, LED Head Lamp, Tonneau Cover
    Hey anyone rocking any aftermarket rear lockers? I was told there are Aussie, lockrite lockers... The only thing I don't want to do is a Lincoln lock...
    I just don't know exactly how to check specs or what works best, or anyone who's done this... I have an 09 acab (2nd gen) .... any help would be greatly appreciated, thanks!
  2. Feb 27, 2013 at 5:23 PM
    Skinny Rogers
    Skinny Rogers U know fish can hear u thinking just b4 u sneeze
    Lance
    NC
    10 taco
    X2. Wanna know as well.
  3. Feb 27, 2013 at 5:26 PM
    blake5995
    blake5995 Well-Known Member
    Blake
    Truckee, CA
    98 Tacoma SR5 4x4 2.7L
    I am driving my spare truck and it has a locker in the rear and it is a detroit truetrac i like it a lot because it is not constantly engaged but i would never ever put a locker in a daily driver. The route i am going on the rig i am building is the ARB air locker because then you can decide when you need it and dont have to deal with it at the grocery store or around town
  4. Feb 27, 2013 at 6:47 PM
    KCDuran
    Kyle
    South Jersey
    5 Lug'n 4 banger
    That rig with the ARB, 5 lug 2WD?
  5. Feb 27, 2013 at 7:17 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    The +05 5-lug uses the same size rear diff as the non-elocker +05 6-lug trucks. The ring and pinion ratios are different but the size of the ring gear is the same. It's commonly called the 8.4" or Tacoma/T100 differential. So the lockers that are meant for the non-elocker 6-lug trucks will fit in the 5-lug trucks. Not too many have put ARB or Richmond lockers in their 5-lugs but there might be a few. I have an Eaton clutch type LSD in mine.
  6. Feb 27, 2013 at 9:09 PM
    KCDuran
    Kyle
    South Jersey
    5 Lug'n 4 banger
    Do it yourself? How much? How is it lasting and do you think it was worth it? Sorry for all the question bombardments
  7. Feb 28, 2013 at 9:01 AM
    KCDuran
    Kyle
    South Jersey
    5 Lug'n 4 banger
    Well looks like I'm going to add a lockright to the back, using the ECGS locker and differential. Ill be regearing to 4.10 as well.... Pretty excited. As soon as everything is on order ill update the progress. ARB is way too much of a hassle so ill go with the easier route lol
  8. Feb 28, 2013 at 9:07 AM
    Manwithoutaplan
    ID
    I just put in two arbs.
  9. Feb 28, 2013 at 9:12 AM
    KCDuran
    Kyle
    South Jersey
    5 Lug'n 4 banger
    Front and back? Did you do it yourself?
  10. Feb 28, 2013 at 9:17 AM
    Manwithoutaplan
    ID
    I had a shop put in the 4.56's gears and front/ rear lockers. If you buy it from East coast gear supply it is pretty straight fwd. But i just did not want to mess with crucial part of the truck. But i have done a 3rd member with a e locker. The front take alot longer, because of the CV's and how it is mounted.
  11. Feb 28, 2013 at 9:22 AM
    KCDuran
    Kyle
    South Jersey
    5 Lug'n 4 banger
    This is what I'm buying and regearing to 4.10
    http://eastcoastgearsupply.com/i-128197-tacoma-t100-8-4-powertrax-lock-right-1615-lr.html
    http://eastcoastgearsupply.com/i-788575-tacoma-8-4-non-eld-t100-tundra-3rd.html
    My buddy told me that an ARB install would be really tough so he said lockrite would be the way to go
  12. Feb 28, 2013 at 9:25 AM
    Manwithoutaplan
    ID
    Are you 4wd Drive?? Because the only thing that can go in the front is the arb. But you can put any thing in the back.
  13. Feb 28, 2013 at 10:30 AM
    KCDuran
    Kyle
    South Jersey
    5 Lug'n 4 banger
    No Im 2wd but I was told ARB can be put in the back... I could be wrong. But yeah it looks like lockrite will be in the back
  14. Feb 28, 2013 at 10:45 AM
    Manwithoutaplan
    ID
    Ok yea arb can go front in back.
  15. Feb 28, 2013 at 10:59 AM
    KCDuran
    Kyle
    South Jersey
    5 Lug'n 4 banger
    So how was your ARB install? Im just looking at all options at this point... The lockrite will keep my back wheels locked until I need to turn, where as the ARB will be, well you know, locked when I want it to be locked.
  16. Feb 28, 2013 at 11:10 AM
    Manwithoutaplan
    ID
    The install took 3 days but that is with re gearing to front/back. As far as is using it, yea i am open/open until i flick the switch then i am fully locked.
  17. Feb 28, 2013 at 11:51 AM
    KCDuran
    Kyle
    South Jersey
    5 Lug'n 4 banger
    Did you use a write up or just go for it? Lol
  18. Feb 28, 2013 at 11:56 AM
    Manwithoutaplan
    ID
    look monkeyproof he has write up on how to install diffs.
  19. Feb 28, 2013 at 11:58 AM
    KCDuran
    Kyle
    South Jersey
    5 Lug'n 4 banger
    Thanks man
  20. Feb 28, 2013 at 11:59 AM
    Manwithoutaplan
    ID
    no problem/.
