Aftermarket lsd
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Marc70, Dec 9, 2015.
  1. Dec 9, 2015 at 6:10 AM
    Marc70
    Marc70 [OP] Well-Known Member
    Marc70
    Northern Ontario
    2012 TRD Sport 4.0L, 6MT
    2” lift, ARB front bumper, steel rear bumper, Trail Gear weld-on sliders, aFe cai, 2lo kit, air bag suspension, RA Motorsports AL skid plates
    i just got a used '08 Taco, and would like to know if installing an aftermarket lsd would be worth it?
    It's a 4 door standard (short box).
    Love the truck, looked at lockers, but think I'd be satisfied with the lsd. I don't plan heavy duty 4wheeling, but do want to get out and play.
  2. Dec 9, 2015 at 6:29 AM
    Pigpen
    Dan
    Northwest Montana
    Look at East Coast Gear Supply. You'll be happy with the Tru Track if you don't feel you need lockers.
    Marc70[OP] likes this.
  3. Dec 9, 2015 at 8:10 AM
    Marc70
    Marc70
    Northern Ontario
    Well, after researching a little more, I think I'd be happier with a locker, which east coast gear also carries.
    Thanks 58 Siesta.
  4. Dec 9, 2015 at 8:37 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  5. Dec 9, 2015 at 8:48 AM
    SpoilsofWar
    SpoilsofWar Well-Known Member
    Wilmington NC
    2014 DCLB 4x4 TRD Sport Super Charged
    Great info Torspd
  6. Dec 9, 2015 at 9:00 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
