Aftermarket lug nut size
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hesher Lord, Aug 6, 2019.
  1. Aug 6, 2019 at 2:53 AM
    Hesher Lord
    Hesher Lord [OP] Well-Known Member
    Biloxi, MS
    I ordered a set of Level 8 MK6 wheels and am going to swap out the lugs for black acorn-style lug nuts. I'm not sure if I need to go with 21mm or 19mm, but my tire tool has both sizes on it in case I need to take them off. Does it matter which size I go with?
  2. Aug 6, 2019 at 3:15 AM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    Probably will need ET lug nuts and will probably need something like gorilla spline drive, 19 may still be too big. 19 min. to try. Aftermarket wheels don't give a lot of space for normal hex lugnuts.
  3. Aug 6, 2019 at 3:57 AM
    Hesher Lord
    Biloxi, MS
    Please forgive my ignorance but I'm not familiar with the terms. From a search it looks like the ET is just extra length for the actual studs? Not sure about the spline drive. I see a lot of people from searches on the forum recommending going to Wheeler's Off Road and getting them from there as well.
  4. Aug 6, 2019 at 4:02 AM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Yes ET stands for extended threads. The tacoma having such short studs they should have them with the aftermarket wheels to get the correct thread engagement for safety reasons.
    These right here will work, wheelers is also a good place to get them.
    https://www.amazon.com/DPAccessorie...8&s=gateway&sprefix=12x1.5+et,aps,135&sr=8-17
    Xx Ares xX likes this.
  5. Aug 6, 2019 at 7:29 AM
    Hesher Lord
    Biloxi, MS
    Good deal. I picked up a set of those from Amazon. I appreciate the help :thumbsup:
    ovrlndkull likes this.
  6. Aug 6, 2019 at 7:30 AM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    No prob
  7. Aug 6, 2019 at 10:54 AM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    Thanks for the link. I've not used a lug like this - that extended length will fit in the lug hole in any aftermarket wheel?
  8. Aug 6, 2019 at 11:08 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    The DPA ones are shiny black,the Gorilla ones are matte black,for those that don't know.
  9. Aug 6, 2019 at 12:46 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Not all aftermarket wheels are drilled to accept an et lug but The level 8s should be since they are set up for Toyotas
  10. Aug 6, 2019 at 12:58 PM
    Fullboogie
    Dave
    Houston
    I've got FN Wheels Six Shooters. Guess I need to call Dustin and find out if these are drilled for them. Thanks man.
  11. Aug 6, 2019 at 2:10 PM
    Jacked Burton
    Jacked Burton Well-Known Member
    35s 4.30s 6speed TruTrac Fx Pros Bilstiens Dakars
    Tires: 35/11.5/17 Toyo AT3s Wheels: FN FX Pro Gunmetal 17s with TRD center caps Zinc Metallic lettering. Yukon 4.30 gears with TruTrac Front Suspension: OME 887 w/5100s, Freedom Offroad UCAs n Superbumps Rear: Archive Hammer Hangers,Dakar Mediums, Bilstien 5125s Ubolt flip n Superbumps, Headlights: Selfmade Retrofits URD shortshift kit Airaid CAI No name throttle controller
    Will these work with the oem 16"s?
    Yeah I realize i need 24 of them.
    https://www.ebay.com/itm/20-Aodhan-...e-Acorn-Lug-Nuts-set-of-20-W-Key/131724146118
  12. Aug 6, 2019 at 3:47 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
  13. Aug 6, 2019 at 3:49 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Should be most truck wheels are drilled and set up for yota but the chevy's can use them. All other vehicles with the same lug pattern have smaller hub bores and longer studs so to fit as many vehicles as they can wheel manufacturers build off the yota then you have to adapt with hub rigs for the rest.
    Hesher Lord[OP] likes this.
