Aftermarket MT shift knobs
Discussion in '3rd Gen. Tacomas (2016-2023)' started by offthewallsurfer, Jan 23, 2017.
  1. May 25, 2019 at 5:13 AM
    #421
    deusxanime
    deusxanime Well-Known Member
    MN
    2020 Cement OR DCSB V6 6MT 4x4 Prem+AdvTech+LED
    I love that TRD cueball knob! Looks like you went with the grommet trick for the boot? Which size?
  2. May 25, 2019 at 5:31 AM
    #422
    rubiconjp
    rubiconjp Well-Known Member
    Austin TX
    I tried both 5/8 and 23/32 ID grommets from Lowe's, both with 1 1/8" OD. The problem is the OD at 1 1/8" was still too small to cover the boot ring. So I went to O'Reilly auto parts and they had these PCV rubber grommets which had no size on the packets. I just eyeballed it, brought along my Lowe's grommet and picked the one with an OD that's larger. I ended up trimming the larger lip of this PCV grommet and the smaller lip is what you see covering the ring.
    BTW I didn't use the alignment nut that came with the TRD ball. It just aligned perfectly on the thread.
    deusxanime[QUOTED] likes this.
  3. May 25, 2019 at 8:07 PM
    #423
    deusxanime
    MN
    I've got my TRD ball (ordered during the 40th anniversary sale), but might hold off on installing it until I trade in for a 2020. Right now I've got the TRD Pro shifter which is pretty nice too, so not as motivated to change it as I would be if I was still running the stock one. I picked up the 1-1/8OD x 5/8ID grommet from Lowes to use with it as was suggested in some threads and Amazon reviews. Thanks for the info on that, if it doesn't work as well as I hope, I can try one from O'Reilly. Also good to know about the alignment nut, I'll probably try it without the nut when the time comes and hopefully it'll align perfectly like yours did!
    rubiconjp[QUOTED] likes this.
  4. Jun 12, 2019 at 11:08 PM
    #424
    Queen Hatchet
    Queen Hatchet Well-Known Member
    Nashville, TN
    2017 TRD OR MT
    Bilstein 5100 all around with 2885 coils up front. OME full pack replacement rear. 1.25” spidertraxx spacers. 255/85/16 Cooper ST Maxx. softoppper.
    SUBD - about to sell some black walnut and cherry wood custom knobs, for anyone interested.
  5. Jun 13, 2019 at 1:30 AM
    #425
    Xer0 SiN
    Xer0 SiN Well-Known Member
    Hilo, HI
    19 TRD SPORT TACOMA / 21 LIMITED RAV4
    this and that...
    jwctaco likes this.
  6. Jun 13, 2019 at 2:28 AM
    #426
    little squirt
    little squirt 808 ALLDAY!!
    808 ALLDAY!!
    487222DF-272E-40C4-9B49-6DDDF6EC451C_zps_92a3a50a544782a8b1a9ec35fbef599916aaf715.jpg
    love mine!
    Speedbird likes this.
  7. Jul 24, 2019 at 2:15 PM
    #427
    MK101
    MK101 Active Member
    Mark
    ‘19 VooDoo Pro 6MT
    Jumped on the gray trd cue ball and quite like it. Used a 3/4” grommet from Home Depot and works good enough for me. Much prefer this to the standard Pro knob...which, by the way, I’d be willing to sell if anybody is interested?
    :burnrubber:
    deusxanime likes this.
  8. Jul 25, 2019 at 8:25 AM
    #428
    jdmdom
    jdmdom Well-Known Member
    APO, AE 09053
    2019 TRD DCSB, 2009 TRD DCSB
    Love that shift knob. Where can I get one???
  9. Jul 25, 2019 at 8:29 AM
    #429
    TexAggie
    TexAggie Well-Known Member
    Eric
    Houston, TX
    OME Lift
  10. Jul 25, 2019 at 8:32 AM
    #430
    jdmdom
    APO, AE 09053
  11. Jul 25, 2019 at 8:33 AM
    #431
    TexAggie
    Eric
    Houston, TX
    OME Lift
    Yeah! I believe it was originally a FJ knob.
  12. Jul 26, 2019 at 7:18 AM
    #432
    notanexpert
    notanexpert Well-Known Member
    Golden, CO
    18 MT TRD pro
    What is the weight difference between the pro knob and the grey knob?
  13. Jul 26, 2019 at 11:45 AM
    #433
    MK101
    MK101 Active Member
    Mark
    ‘19 VooDoo Pro 6MT
    I didn’t weigh them, but they feel pretty similar in the hand. I love the feel of the cue ball and it shifts beautifully (but so did the stock one).
  14. Jul 26, 2019 at 12:45 PM
    #434
    Xer0 SiN
    Hilo, HI
    this and that...
    the gray one isnt weighted so its definately a meager amount.
  15. Jul 26, 2019 at 12:56 PM
    #435
    jayuu
    jayuu Well-Known Member
    Central Maine Highlands
    2017 Black TRD Sport DCSB 6 sp manual
    7.2 oz/204g
  16. Jul 26, 2019 at 2:00 PM
    #436
    Rockoma5
    Rockoma5 Well-Known Member
    St Louis
    2019 TRD Sport Lifted
    I have this exact one in mine from billetwerkz It is the weighted version and nice. People told me it will be super hot and burn me but yeah not so much...on a blistering hot day it is room temp....I am sure when its cold though I bet it is cold but whatever.
    MK101 likes this.
  17. Aug 14, 2019 at 8:08 PM
    #437
    Rafterman
    Rafterman Member
    Southern Alberta
    MGM '17 Sport MT
    Here's what I used to mod the shifter knob. The rubber grommet fits like a glove.
  18. Aug 14, 2019 at 8:35 PM
    #438
    urbanplanner
    urbanplanner Well-Known Member
    washington state
    At the risk of going off topic, is anyone running a better looking shift boot for the MT? There is a short thread on this for the AT and the e-brake boot from Renline, but nothing for the MT. I prefer the older look where some of the shift lever was visiable.C88341F5-6DA2-4A6A-A4F1-B2724005BDEA.jpg
  19. Aug 15, 2019 at 9:25 AM
    #439
    ArmandHammer83
    ArmandHammer83 This truck is AMAZING
    Raymond
    Alabama
    2018 Tacoma AC V6 MT 4x4
    none yet
    there's a guy on here that has it like your interested, maybe he'll comment or someone can add to it... basically under the collar is a zip tie you can cut and adjust the amount of lever is visible...be aware you have take off the surrounding plastic to expose the zip tie...i haven't done it i just remember someone mentioned they did...good luck let us know what you do and what you think after if you do it
  20. Aug 15, 2019 at 9:45 AM
    #440
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I thought I had posted it here, but it looks like I didn't.
    Here's my setup:
    -- @7r41lbr34k3r full delrin knob (162g) and MT boot collar cover
    -- Matte black boot collar (sanded / painted)
    -- Redline shift boot
    I did all three Redline pieces, but I would recommend against the e-brake boot and padded console cover. The e-brake boot itself is nice, but the bracket option is just the glued in wire. It is too small of a gauge compared to the OEM. So forming it (ships flat) and keeping it clipped in is tricky. The console cover is finicky to install, does not fit well, and the foam is wayyy too soft (pretty much useless for adding height). I intend to get the console cover redone by someone with skills.
    The Redline shift boot does rock though.
